Error Aspen Plus.
aspen
7 replies to this topic
#1 wsnice
wsnice
  • 4 posts
Posted 06 April 2023 - 12:25 PM
in Aspen Plus, after selecting a component (for example, WATER), when you click on "Run" (the error "Unexpected end of file. The results are not loaded", the properties of substances from the component database are not loaded. In the "Control panel" the following information:
<< Loading Simulation Engine 21:09:53 Thu Apr 6,
2023>>->Processing input specifications ...
*   WARNING IN PHYSICAL PROPERTY SYSTEM
MW MISSING FOR COMPONENT NH3
NRTL BINARY PARAMETERS FOR ALL COMPONENT PAIRS ARE ZERO,
YOUR RESULTS MAY NOT BE ACCURATE. PLEASE REVIEW AND PROVIDE BINARY
PARAMETERS AS APPROPRIATE.
What to do?
  • 1,554 posts
Posted 06 April 2023 - 01:38 PM
Make sure your components are entered as 'conventional' which uses the built-in database. You may have added them as 'user added' instead.
#3 wsnice
wsnice
  • 4 posts
Posted 07 April 2023 - 12:30 PM
Am I doing it right?
  • Attached File  2.png   431.39KB   3 downloads
  • Attached File  1.png   560.57KB   3 downloads
Edited by wsnice, 07 April 2023 - 12:31 PM.
#4 latexman
  • 1,810 posts
Posted 07 April 2023 - 12:48 PM
You need to resolve the Methods tab (red/white circle) on the picture on the right.
I see no issue on the picture on left.
#5 wsnice
wsnice
  • 4 posts
Posted 07 April 2023 - 01:23 PM
It seemed to me that after selecting the component Aspen should redirect me to the "Analysis of properties", and I get into the control panel with this error "Results not loaded"
I started to master the program not so long ago, maybe I don't understand something, I apologize maybe for stupid questions...
  • Attached File  3.png   449.02KB   1 downloads
#6 Pilesar
  • 1,554 posts
Posted 07 April 2023 - 06:13 PM
Your screenshot shows you are running version 8 of the program. The latest version is 12. If you cannot run the program, the fault may lie with the installation.
#7 wsnice
wsnice
  • 4 posts
Posted 07 April 2023 - 11:07 PM
I tried to install 8,9,10,12 and 14 versions. It's the same mistake everywhere. I do everything according to the instructions
#8 breizh
  • 6,715 posts
Posted 07 April 2023 - 11:12 PM
You may need to talk to Aspen tech support.
