Gas Flow Units In Hysys
9 replies to this topic
#1 MimoDec80s
MimoDec80s
  • 3 posts
Posted 15 May 2023 - 09:22 PM
Hi
Is there any way to enter the gas Flow in hysys in Nm3/hr , normal condition ( 0°C, 1 atm ) !!
Edited by MimoDec80s, 15 May 2023 - 09:23 PM.
#2 Bobby Strain
Posted 15 May 2023 - 10:31 PM
What are the conditions that are used in HYSYS SI? Check them first. If those are the conditions, you can probably enter them as such. Clone a new set of units if necessary.
#3 Pilesar
  • 1,554 posts
Posted 15 May 2023 - 10:34 PM
Nm3/hr is a molar flow rate so look under molar flow rate units.
#4 Nikolay_
Nikolay_
  • 163 posts
Posted 16 May 2023 - 07:12 PM
Adding to Pilesar comment you need divide Nm3/hr to 22.4 to obtain molar flow kmol/h.
Edited by Nikolai T, 16 May 2023 - 07:12 PM.
#5 MimoDec80s
MimoDec80s
  • 3 posts
Posted 17 May 2023 - 12:22 AM
I am sure there is no Nm3/hr in the units available
#6 MimoDec80s
MimoDec80s
  • 3 posts
Posted 17 May 2023 - 12:25 AM
I can already calculate it manually sure , but I thought there is a unit called Nm3/hr not to waste time
#7 SilverShaded
SilverShaded
  • 237 posts
Posted 17 May 2023 - 01:01 AM
Pilesar is correct, you can define molar flow in Hysys to be Nm3/hr.  Either when you enter the value or by default by changing the unit set.
#8 Pilesar
  • 1,554 posts
Posted 17 May 2023 - 05:42 AM
It is a common mistake to look for Nm3/hr when entering a volume flow rate because the units of measure look like they should be a volumetric flow rate. Enter the stream rate as molar flow and then look for Nm3/hr for the units of measure. You are not the first to have trouble with this! It is very common.
#9 Nikolay_
Nikolay_
  • 163 posts
Posted 18 May 2023 - 07:06 PM
Thank you.
#10 Bobby Strain
Posted 20 May 2023 - 04:02 PM
Pilesar,
      You assume we all know how to enter numeric values in units other than the default unit. I know, but there are probably few others.
