Pvrvs Set Pressure Tolerance
#1 Instnapp05
Instnapp05
  • 3 posts
Posted 12 June 2023 - 08:22 AM
Good Morning All,
I would appreciate if anyone can advise here the acceptable set pressure tolerance and the standard used for testing PVRVs. I have done numerous research and all that I came across mentioned that allowable is +/- 10% for pressure/vacuum setting, however there is no document/standard to support same. I went through API2000, API 2521,API 576 & ISO 28300, but none of them mentioned the allowable tolerance.
Thank you in advance for your cooperation and look forward to your response at your earliest convenience.
#2 shvet1
shvet1
  • 476 posts
Posted 14 June 2023 - 08:20 AM
What does PVRVs stand for?
#3 breizh
  • 6,715 posts
Posted 14 June 2023 - 08:28 AM
Shvet1
PVRV stands for pressure/vacuum relief valve. I guess "s" is a plural form?
