Terminal Velocity Formula For Cube Particles
#1 jordan1111
jordan1111
  • 31 posts
Posted 15 June 2023 - 07:33 PM
Hi Everyone,
I am wondering if anyone has any recommended formula to calculate the terminal velocity for a cube particle.
I found a lot of literature for sphere particles, but not for cube particles.
Thanks a lot.
Jordan
  • 6,715 posts
Posted 15 June 2023 - 10:43 PM
You may want to consider a spherical particle with the same area than a cubic particle.
Edit:
pi*d^2=6*a^2
d = sqrt (6/pi) *a    with a =side cube and d=equivalent diameter of the sphere.
d=1.382 *a
Vt:
https://www.omnicalc...rminal-velocity
Cd:
https://en.wikipedia...rag_coefficient
my 2 cents
#3 Pilesar
  • 1,554 posts
Posted 15 June 2023 - 11:44 PM
I would choose 0.8 for drag coefficient assuming the cube would freely rotate and on average be edge-first. Corner-first would have drag a bit above 0.5. Flat-side first would be 1.05. Drag values are based on this reference:  https://qph.fs.quora...72319806a83b2e7  A terminal velocity calculator with formulas referenced can be found here: https://www.gigacalc...-calculator.php
Edited by Pilesar, 15 June 2023 - 11:46 PM.
#4 jordan1111
jordan1111
  • 31 posts
Posted 19 June 2023 - 08:09 AM
Thank you!
