Pump Suitable For Thick Slurry With Fibers
#1 kangas
kangas
  • 127 posts
Posted 23 June 2023 - 01:54 AM
I have a slurry of animal dung mixed with 2 parts of water in an underground tank. In the slurry there are animal feed fibers.
I want to mix and transfer the slurry using pump. We tried different submersible pumps but they clog over time.
What's the most suitable type of pump at a reasonable cost?
I use PVC piping PN6 for transfer
Edited by kangas, 25 June 2023 - 07:51 AM.
  • 6,715 posts
Posted 23 June 2023 - 04:53 AM
Google Pig tail pump, this can handle slurry.
Not sure whether it's suitable for your application.
#3 snickster
snickster
  • 82 posts
Posted 23 June 2023 - 06:54 PM
I have used progressive cavity pumps to pump limestone slurry for power plants, pulp slurry for paper mills, and waste water slurries for waste treatment facilities before, it is a very common pump to use when thick aqueous mixtures are present.  Typical the liner is an elastomer or other soft material.  The trick is selecting the right liner for the application. for both chemical and abrasive resistance.  Problem is if the pump runs dry you may ruin the liner and have to repace it which is rather expensive.  Would need dry running protection controls.
Edited by snickster, 23 June 2023 - 07:49 PM.
#4 shvet1
shvet1
  • 476 posts
Posted 24 June 2023 - 12:16 AM
Not enogh info for advise. Best to consult a reputale manufacturer, e.g. KSB.
For info see
Slurry Pump Basic by Metso Minerals
Slurry Pumping Handbook by Weir Group
#5 breizh
  • 6,715 posts
Posted 24 June 2023 - 12:36 AM
To add to my previous reply let you consider the booklet attached, mentioned by shvet1.
