Hardness In Hot Cast Polyurethane System
Posted 12 September 2023 - 01:25 AM
Posted 12 September 2023 - 05:59 AM
I suspect uneven temperature. Can you rotate the mold or the tubes while curing?
Posted 12 September 2023 - 06:48 AM
Lately we faced the problem
What changed? RMs, suppliers, mixing, heat transfer, equipment, instrumentation, batch instructions, etc? It sounds like everything was fine for some time, then much different surface hardnesses started appearring. Something in the process must have changed. Did the much different surface hardnesses appear suddenly, or gradually?
Posted 14 September 2023 - 01:15 AM
I'm with Latexman, for sure something has changed over the time. Go back to your production when the quality was OK and check for the changes, if any. Review all the process parameters, the MOC on the equipment, the raw materials.
Note:
I've in mind a change of Raw mat supplier who affected the quality of the final product for months. Sometimes people want to save $ through competition and create big losses.
I cannot offer more, outside my expertise.
Good luck,
Lime SystemStarted by Guest_Dorota86_* , 01 Mar 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Using Different Types Of Prvs To Protect The Same SystemStarted by Guest_FarrahC_* , 09 Dec 2024 |
