Pressure Drop Across A Suction Strainer Of A Pump
hysys pump strainer pipeline hydraulics pressure drop fluid mechanics
8 replies to this topic
#1 nasim304
nasim304
  • 3 posts
Posted 21 September 2023 - 06:19 AM
Can anyone please help me to find out the suction strainer of a pump to calculate the pipeline pressure drop in ASPEN HYSYS V.11
Thanks in advance.
  • 1,554 posts
Posted 21 September 2023 - 07:22 AM
A clean strainer has very low pressure drop (negligible) but a clogged strainer has very high pressure drop! There are different types of strainers. A witches hat strainer should have more open area than the open pipe area. Perhaps treat it as you would an elbow for pressure drop purposes if you assume it clean.
#3 shvet1
shvet1
  • 476 posts
Posted 21 September 2023 - 08:00 AM
What strainer an what purpose are you supposing to insert in suction? To answer - describe in details.
#4 nasim304
nasim304
  • 3 posts
Posted 21 September 2023 - 10:42 AM
like a y strainer with 100 mesh in the suction of a naphtha delivery pump...
#5 latexman
  • 1,810 posts
Posted 21 September 2023 - 11:12 AM
The Y-strainer vendor should have documentation on pressure drop.  Consult them and/or their website.  Who is the vendor?
#6 breizh
  • 6,715 posts
Posted 21 September 2023 - 06:28 PM
Let you try this application and /or contact vendors.
Pressure Drop Online-Calculator PDA (pressure-drop.mobi)
Edit:
Using your favorite search engine:
https://kcbkk.com/wp...r_Yoshitake.pdf
Many more .
#7 shvet1
shvet1
  • 476 posts
Posted 21 September 2023 - 10:56 PM
What purpose and why 100 mesh, not let say 10 mesh? Is it new design, modification or validation of existing?
Edited by shvet1, 21 September 2023 - 10:59 PM.
#8 snickster
snickster
  • 82 posts
Posted 22 September 2023 - 12:51 AM
Winston Royal Guard has extensive pressure drop curves for different types of strainers.  You can possibly use their data for pressure drop in your calculations.  I typically use their pressure drops for pressure loss estimates not knowing what actual vendor in the end will supply the strainers.
Edited by snickster, 22 September 2023 - 12:56 AM.
#9 Said Salim
Said Salim
  • 98 posts
Posted 22 September 2023 - 08:42 PM
You may use Ankurs spreadsheet for DP across strainer.
https://www.cheresou...-for-strainers/
