Solvent Carryover Emissions In Absorption Process
#1 TeeEng
TeeEng
  • 9 posts
Posted 24 October 2023 - 09:32 AM
Hi Folks,
Can I pick your brain on an absorption emissions scenario?
I am running a model using an amine based solvent to capture CO2 from a flue gas in a contactor (absorber), however, about 600 ppm of solvent is been carried over with the treated flue gas exiting the contactor. To recover this, I added a two water wash columns down stream of the contactor overhead and with this I was able to reduce the solvent carry over to ~100 ppm and ~40 ppm at the outlet of the two water washes respectively. This client requirement is to get the solvent carry over down to <1.5 ppm and the one way I know to achieve this is to add an acid wash downstream of the 2nd water wash but with this, I can remove the 40 ppm solvent carryover but this would be unrecoverable which will add up and result to about ~35% solvent makeup per annum. This is huge and not economically competitive so I am looking for other ways to reduce the solvent carryover or loss to about 2 - 5 ppm.
Kindly share your experiences on how I might achieve this.
Thanks folks,
TeeEng.
  • 1,554 posts
Posted 24 October 2023 - 12:37 PM
Solvent losses seem inevitable with some amines worse than others. Further cooling the vapor stream and adding high-tech mist eliminators is the approach I might consider. There is an economic optimum, but 35% amine loss per year may just be an operating cost. Are you certain those losses are out of line with industry results?
#3 TeeEng
TeeEng
  • 9 posts
Posted 24 October 2023 - 01:26 PM
Thank you for your response.. Yes the solvent loss is humongous. Typical high pressure gas sweetening with MDEA will have ~1ppm solvent carry over with the sweetened gas. Not so sure about this low pressure system
The ~40ppm solvent emission are in vapor phase so not so sure high-tech mist eliminators will be able to recover that - What do you think? Do you have a vendor recommendation I might be able to consult with?
Folks, please share your experiences.
TeeEng!
Edited by TeeEng, 24 October 2023 - 01:30 PM.
#4 breizh
  • 6,715 posts
Posted 24 October 2023 - 09:06 PM
You may want to contact Sulzer about mist eliminator.
