Priming For Pump
#1 rudiawan
rudiawan
  • 3 posts
Posted 08 December 2023 - 03:59 AM
Attached File  priming pump.jpg   90.94KB   0 downloadsi need the advise for sizing the priming system for the pump (the pump configuration as attached)
What is the total estimated non-flooded suction volume that needs to be filled with water?
What is the maximum estimated elevation difference from the water source to the top of the pumps?
What is the estimated time required for the prime to be established?
Thanks in advance
rudiawan
Edited by rudiawan, 09 December 2023 - 08:12 AM.
  • 6,715 posts
Posted 08 December 2023 - 04:41 AM
No attachment.
How do you intend to prime the pump? Priming pot or ejector?
Hope you have installed a foot valve and a net to prevent debris to enter the suction line.
The volume concerned is the suction line, from the net to the pump suction.
A google search will help you, key words Priming pot.
BTW, did you consider a self-priming pump or an immersed pump?
Note: No need to highlight your post, it's considered not very respectful.
#3 latexman
  • 1,809 posts
Posted 08 December 2023 - 05:23 AM
No attachment.  Edit the OP, click "Use Full Editor", the document attachment functions are below the text window.
#4 shvet1
shvet1
  • 476 posts
Posted 12 December 2023 - 12:06 AM
What is the total estimated non-flooded suction volume that needs to be filled with water?\
Not applicable
This is the result of NPSHA and intake design
In your case - immidiatelly
Poor design. An operating team will need a vacuum source to evacuate the air pocket and avoid cavitation or losing of priming.
See ANSI/HI 9 sections 6.1, 6.6, 8 for details.
Note that there are other industry standards/practices for pump piping.
Note that self-priming is an issue - you should review and implement one of applicable start-up methods for this pump.
Edited by shvet1, 12 December 2023 - 05:38 AM.
#5 breizh
  • 6,715 posts
Posted 12 December 2023 - 03:57 AM
Consider this resource from SIHI , basic principles for thedesign of centrifugal pump installation .
