Multiple Effect Evaporator Calculation With Multiple Components
evaporator multiple effect
#1 addiesalsabil
addiesalsabil
  • 5 posts
Posted 13 January 2024 - 12:40 PM
Hi all,
I'd like to evaporate a mixture of propylene oxide, water, propylene glycol and dipropylene glycol in multiple effect evaporator, in this case, triple effect evaporator. I'd like to evaporate all of the propylene oxide and a big fraction of water, leaving small fraction of water, propylene glycol and dipropylene glycol in the liquid product.
The question are, how do I calculate the needed temperature and pressure to obtain the vaporized and liquid product with the specification that I'd like to achieve? And also, how do I calculate the boiling point rise (BPR) for each effect as most of the calculation examples are in binary component?
I hope this makes sense.
Kind regards,
Addie
  • 6,715 posts
Posted 14 January 2024 - 01:49 AM
You should get data from literature or lab tests.
I've attached documents to support your calculation.
#3 addiesalsabil
addiesalsabil
  • 5 posts
Posted 14 January 2024 - 08:30 AM
Thanks for the recommendations, Breizh!
#4 shvet1
shvet1
  • 476 posts
Posted 14 January 2024 - 10:40 PM
Do you want to provide this manually or using a software?
