Two Psvs Have More Or Less Same Set Points
#1 johneyissac98
johneyissac98
  • 19 posts
Posted 16 January 2024 - 09:26 AM
My question is ,
1. Why distillation column overhead has two psv which has almost same set points i.e psv1= 4.5ksc , PSV2 = 4.6ksc
  • 1,566 posts
Posted 16 January 2024 - 11:21 AM
Possibilities for the reason for two PSVs: plant might switch between them for maintenance or one was not large enough for the scenario. The close set points may be a mistake. Somewhere there should be calculations for the required pressure relief of this column. If you find them, report your conclusions so we can learn also.
#3 shvet1
shvet1
  • 476 posts
Posted 16 January 2024 - 11:31 PM
What do you mean 'set point'? Set pressure? Cold differencial test pressure? Has those been designed&installed at the same time? Are those identical?
What jurisdiction? ASME or PED?
Edited by shvet1, 16 January 2024 - 11:32 PM.
#4 fallah
  • 5,019 posts
Posted 17 January 2024 - 12:34 AM
johneyissac98, on 16 Jan 2024 - 2:36 PM, said:
My question is ,
It might one PSV is operating and another is standby, if so there would be no problem for minor difference between set points.
Please upload a snap shot of the PSVs arrangement from relevant PID to get a more proper response...
