Pump-Continuous Flow After Trip
#1 stu
stu
  • 89 posts
Posted 28 January 2024 - 09:12 PM
dear all,
Please clarify in real operation is there any continuous flow from pump even after pump stops , if there is pressure difference available across the pump after trip/stop. For example pump suction has 3 barg & its discharge pressure is lower than suction pressure after trip.
thanks, stu
#2 shvet1
shvet1
  • 476 posts
Posted 28 January 2024 - 10:43 PM
Such event is possible. You should provide a hydraulic study of this system to find the answer.
#3 fallah
  • 5,019 posts
Posted 29 January 2024 - 12:51 AM
Please clarify in real operation is there any continuous flow from pump even after pump stops , if there is pressure difference available across the pump after trip/stop. For example pump suction has 3 barg & its discharge pressure is lower than suction pressure after trip.thanks, stu
Yes, it's possible in a pump with mentioned conditions, but it would be no longer a pump and converts to a water turbines!
