Air Consumption For On Off Valves
#1 itsmetinnie
itsmetinnie
Posted 11 March 2024 - 09:26 AM
I would like to know how can I calculate for the correct air consumption of the actuators that I currently working on.
For example, the actuator model is CBB520-SR80-CW and the Actuator volume is around 2.5 L. I need to provide the air consumption in Nm3/hr. Plant air is 5 barg, valve is fail close with closure time of 4sec. Our vendor provided a value of 2 Nm3/hr as the air consumption value but I doubt if its correct since they have not considered the air pressure.
Please assist  :unsure:
  • 6,714 posts
Posted 11 March 2024 - 06:14 PM
You may want to contact these guys:
 https://globalsupply...an-Stockist.pdf
Note: I don't understand your last sentence, they provide you data in Nm3/h, it's up to you to convert, if necessary, at your pressure/temperature conditions.
https://instrumentat...r-onoff-valves/
Good luck.
