Vacuum Distillation
vacuum distillation
#1 hysyshunter
hysyshunter
  • 12 posts
Posted 12 March 2024 - 07:27 AM
Currently i am designing a vacuum distillation column to separate glycerol from propylene glycol, however i need to be able to simulate and design how the vacuum is actually created in the column, through research and advice ive been informed that the vacuum is created through vacuum pumps and stem ejectors, and when i looked online i saw the primary use of oils and a fired heater to before the column. So im asking whether i need to incorporate oil and steam into my design or just vacuum pumps, because i am not cracking oil.
#2 hysyshunter
hysyshunter
  • 12 posts
Posted 12 March 2024 - 08:08 AM
Sorry 've realised all i need to do is have a vacuum pump to create the vacuum, does anyone know if this is possible in HYSYS? i cant find any videos online
#3 Pilesar
  • 1,552 posts
Posted 12 March 2024 - 01:10 PM
Typically, the model maker will set the column pressure to a value that is reasonably achievable. The vacuum system itself will be designed separately. To achieve the vacuum, you will condense the overhead vapor as much as possible with a heat exchanger and pull away any remaining uncondensed vapor with steam jets or vacuum pump. The condensing step is important because it reduces the amount of vapor sent to vacuum and also recovers valuable product.
#4 Eduard Osipov
Eduard Osipov
  • 3 posts
Posted 13 March 2024 - 08:42 AM
You can see some articles about vaccum systems modelling in HYSYS, Unisim and ChemCad.
https://www.mdpi.com/2305-7084/8/2/31
https://www.mdpi.com...-9717/9/11/1865
https://www.mdpi.com...-9717/8/11/1333
https://iopscience.i...3/6/062006/meta
https://link.springe...891-019-02020-7
#5 breizh
  • 6,714 posts
Posted 13 March 2024 - 08:46 PM
You have two separate problems:
  one is the simulation of your column operating under vacuum, just set the pressure which is one parameter of the simulation.
  For the vacuum different technologies are available, let say vacuum pump and ejectors.
  Vacuum pump could be dry vacuum pump or liquid ring vacuum pump.
  For ejector, I believe we are talking steam ejector, it depends very much on how deep you need it. It will be single or multiple stages with         intermediate condensers.
