Distillation Column Decommissioning Checklist
distillation column decommiss
#1 m.bhut
m.bhut
  • 6 posts
Posted 08 April 2024 - 05:47 AM
Can anybody will help to provide Distillation column decommissioning checklist?
#2 shvet1
shvet1
  • 476 posts
Posted 08 April 2024 - 11:31 PM
Is this what you are looking for?
https://www.amazon.c...k/dp/0128240490
Edited by shvet1, 08 April 2024 - 11:33 PM.
#3 breizh
  • 6,715 posts
Posted 09 April 2024 - 12:02 AM
Shvet1,
Decommissioning!
m.bhut
A few steps,
Work permit procedure in place for all the activities,
Start with isolation (blinds)
Cleaning of the tower with chemicals (caustic soda solution for example) and rinse with water (plenty), make sure you have the capability to store and treat /dispose the dirty water,
Opening of the manholes,
Atmosphere analysis (continuous) before starting inspection and remove equipment.
Etc,
#4 shvet1
shvet1
  • 476 posts
Posted 11 April 2024 - 12:25 AM
Sorry
@m.bhut - is this what you are looking for?
Shut down (stopped)
Pumped out
Cooled down to 40°C (outdoor) or 60°C (indoor)
Decompressed to atm pressure
Drained
Neutralized
Washed / rinsed
Passivated
Steamed out, cooled down again, condensate drained
Purged with inert gas
Purged with air
Positively isolated
Operating zones and escape routes labeled / tagged / segregated
Manholes / accessholes / sightholles opened
Exposed to ambient air, vented, dryed
Positive tests results obtained from column top and bottom both (toxic&flammable components; O2 > 19-21%v (depends on jurisdiction))
Visually inspected by a supervisor
Workers instructed and equipped with PPE and emergency means (e.g. antidotes or water hoses for pyrophoric self-ignition suppression)
Personnel and persons in charge at neighbouring locations warned
Work permission signed and archived
Works are allowed to begin
Edited by shvet1, 11 April 2024 - 11:18 PM.
#5 Jaiganesh
Jaiganesh
Posted 14 April 2024 - 01:56 PM
1) Cleaning of the column must be performed properly.
2) All the drains must be propelled drained and check.
3) Proper condition of the equipment must be equivalent to atmospheric condition temperature, pressure and not limited to.
4) All the LOTO procedures must be followed.
5) Pipe opening permit shall be initiated and then start opening of all the pipe using tools but no hot work shall be performed.
6) Initiate the permit for equipment decommissioning. After that distillation tower shall be dismantled from flange of each segment. Each segment must be lifted by crane and shifted to location safely. All this activity can be performed without hot work (without welding and cutting)
Hope this might help you in your professional work.
