hi guys
thanks for your helps.
in the our site, the designer use of wafer check valve on the flare gas line. this check valve install on the vertical line. the outlet gas goes to the flare. based on ISOMETRIC documents location and flow direction are correct. my question is do you think this check valve type should be on the vertical line or horizontal line? so, if the gas back to vessel can the check valve flapper close the back flow?
thanks
8888888.jpg 39.19KB
0 downloads
888888888.pdf 249.58KB
11 downloads
