Flash Drum And Separator
#1 Abdellahi
Abdellahi
  • 5 posts
Posted 28 May 2024 - 02:20 AM
Hello everyone
I am a student working on my final year project.
I am currently working on a project on which I have to separate a two-phase mixture. This two-phase mixture is obtained after a flash through a valve. I contacted a supplier who recommended a flash tank just after the valve then a separator. I don't understand why I need two separators. can't the flash balloon do the job alone. I should point out that after the flash I have a small percentage of steam. Is it because of this that I will need two separators.
the separator and the flash balloon are the same device? just one is used after a flash why is it named like this?
I'm at the end of my studies but unfortunately I don't have any perspective on all this.
Thank You
  • 6,715 posts
Posted 28 May 2024 - 04:50 AM
After the valve you only need 1 drum with 2 outlets (liquid /gas).
note: To clarify with you, your liquid is a single phase, not a mixture of organic + aqueous phases?
otherwise, you will need a separator to separate the liquid phases.
In the future, you need to provide better information about your process to get a better answer.
CheCalc ‐ Equipment
#3 Abdellahi
Abdellahi
  • 5 posts
Posted 28 May 2024 - 08:30 AM
Hello breizh,
Thank You for the answer and  the document.
Yes, my liquid is a single phase.
To clarify the topic,
I have a large amount of liquid coming out of my process. I want to recover steam from this liquid to reintroduce into my process. So I expand the liquid in order to obtain steam by <Flash>.( If you have a another method to get steam from this liquid, I would like to know since I am at the end of my studies and developing other methodologies will be well received )
The vapor obtained after the flash is very low at around 6%. But at the end I want to recover very dry vapor.I want steam with a humidity level less than 5%.
I think the supplier offered me two separators because in my opinion after the first separation, the steam that comes out will be very humid so he offers a second separator to reduce the humidity.
#4 breizh
  • 6,715 posts
Posted 28 May 2024 - 10:43 PM
A booklet to support your work
