Steam Sparger Design
Posted 24 June 2024 - 02:42 AM
I have to design a in-house steam sparger for wastewater treatment. Does anyone have any design guide document for same?
I have gone through Mott steam sparger documents for same but, that doesn't specify the orifice area calculation.
Your help is highly appreciated!
Posted 24 June 2024 - 05:19 AM
I guess the documents you are referring to are those attached.
Why don't you drop them an email, they are the specialists?
Edit: Another document is attached.
Posted 24 June 2024 - 06:36 AM
Hii all,
Not really. As breizh suggests, send out a performance specification to at least 3 vendors and let the experts design it for you. Is it a single point steam sparger, or a multiple point steam distributor sparger? A sketch is worth a thousand words!
Posted 24 June 2024 - 10:35 PM
Thanks for the documents breizh! I will drop mail as it looks bit tedious.
Posted 24 June 2024 - 10:44 PM
sparger is being used to sparge steam in wastewater stripper for VOCs removal. I guess that makes it a single point steam sparger.
Hii all,
Posted 29 June 2024 - 01:39 AM
Note that you are asking for a proprietary design and know-how
Posted 01 July 2024 - 10:38 PM
Hii shvet1,
Thanks for your reply!
I found Ankur's manual for design of liquid and gas distributors/spargers on same site. As it is a trial run, company is going with in-house design first.
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
