Ammonia Gas With Water
#1 James Clerk Maxwell
James Clerk Maxwell
  • 5 posts
Posted 09 September 2024 - 02:02 PM
Hello ChemEs,
I have a flow with 23 kg/h of ammonia (gas) and 56 kg/h of steam (gas water) all at 1 atm and 90 ºC. Im using a heat exchanger in order to condensate the water, dropping the temperature to 25 ºC.
How can i calculate the amount of ammonia dissolved in the liquid water after the condensation?
Thanks in advance
#2 latexman
  • 1,810 posts
Posted 09 September 2024 - 04:24 PM
Perry's handbook has some water/ammonia equilibrium data that might be useful to you.
#3 breizh
  • 6,715 posts
Posted 09 September 2024 - 09:38 PM
The easiest way should use a simulator.
Note: @ 90 C 1 ATM water is liquid!
Exothermic reaction.
Solubility of NH3 in water is 32 g/100 ml water @ 25C
https://www.engineer...ter-d_1148.html
My experience with Brine is NH3 about 90 g/l in solution and NH4OH aqueous solution @ 12 mole/l.
My 2 cents
#4 shvet1
shvet1
  • 476 posts
Posted 10 September 2024 - 12:21 AM
I personnaly have such experinece with ammonia dissolution in water.
We had to utilize ~100 40L NH3 cylinders. We welded a cylinder-sized pool and filled it with water so a cylinder valve was ~30cm deep. Me personally emptied first ~5 bottles adjusting valve opening by hand and saw as NH3 bubbles are coming out and disappearing being dissolved in water.
Moreover we had a sporadic practice emptying NH3 kettle shell&tube vaporizer by sending to a sparger in an 50m3 open process vessel filled with water and reported no NH3 breackthroughs to atm
So my answer is - do not believe them. In yours concentration range NH3 is totally dissolved in water. The proper mixing is the only issue.
Edited by shvet1, 10 September 2024 - 03:38 AM.
#5 latexman
  • 1,810 posts
Posted 11 September 2024 - 06:12 AM
30% ammonium hydroxide is commercially available, so my first guess would be almost all the ammonia is dissolved in the water, it depends on the mixing, however the ammonia will still be quite pungent! Ammonia and water have quite the affinity for each other.
#6 breizh
  • 6,715 posts
Posted 11 September 2024 - 11:07 PM
Shvet1,
Have you ever read a MSDS about NH3?
Your knowledge about the risk associated with NH3 has worried me very much. Be cautious when you reply to post from student.
Based on 10 years' experience as technical manager in a soda ash plant in Europe.
#7 shvet1
shvet1
  • 476 posts
Posted 16 September 2024 - 12:02 AM
Yes, I have. And I am able to tell more about NH3 safety than has been written in datasheets and most handbooks.
For example I can tell about the near-miss: NH3 tank sudden rupture that leads to evacuation of middle size town and ban of construction of large single volume NH3 tanks at territory of a continent.
Do you consider I should not share a private experience the real facilities are practicing? Are fairy tales of excellent elves riding white horses at green hills of Middle-earth preferred?
Edited by shvet1, 16 September 2024 - 07:15 AM.
