How To Arrange The Heating Coil?
heating coil heat exchanger
#1 nhuthoahuynh13
nhuthoahuynh13
  • 5 posts
Posted 17 October 2024 - 08:39 PM
Have a good day everyone!
have a project to design heating coil for HFO Storage Tank.
Based on the heat loss calculation, I calculated the required low pressure steam.
Now I need to arrange the coil properly (1 layer / 2 layers? or 1 long coil or seperate into shorter coils? or something like that?) in order to ensure the heat transfer effectively.
Can anyone help me if there's handbook or reference that I need to refer?
Besides that, If you have any realiable reference for heating coil calculation template / handbook. I am really appreciated it if you share with me.
Thanks for advanced.
  • 6,715 posts
Posted 17 October 2024 - 10:17 PM
A good start will be Perry's chemical engineers' handbook. They have a section about coil.
Attached a document to support your work.
Note: Try the search engine in this forum.
#3 nhuthoahuynh13
nhuthoahuynh13
  • 5 posts
Posted 18 October 2024 - 10:59 AM
Thanks for your support.
The heating coil configuration I want to design as the picture below. I'm so sorry because I can not share the exactly concept but the idea design is something like that.
Do you have any reference / standard for design this heating coil configuration? I need to know how to arrange the coil for the most effective heat transfer. (Because I think the pressure drop will affect to heat transfer; at the same the total length of coil, but heat transfer of a long coil may be lower than shorter coils).
I hope my explanation is clear,
Best Regards,
