Vacuum System
Posted 21 October 2024 - 05:43 PM
What is the working principle of liquid ring vacuum pump?
Posted 21 October 2024 - 06:12 PM
Let you study these brochures..
other technologies are available like dry vacuum pump.
A Google search should help you out.
Posted 22 October 2024 - 03:01 AM
A liquid ring pump is basically a positive displacement pump where the liquid functions as the piston. The ingenious concept of having the impeller not on the same center line as the volute causes the liquid to move up and down relative to the impeller fins. I'm sure you will find some visual simulations on the web.
Posted 22 October 2024 - 03:01 PM
And this movement of the liquid causes the vacuum in the volute, right?
Posted 22 October 2024 - 09:27 PM
Posted 23 October 2024 - 12:47 AM
Lime SystemStarted by Guest_Dorota86_* , 01 Mar 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
