Nitrogen Leak Test On Pipe
leak test nitrogen pipe pipeline
#1 mesbah
mesbah
Posted 24 October 2024 - 09:13 PM
Hello everyone,
I’m looking to calculate the number of single nitrogen cylinders required to carry out a leak detection test on pipe(volume of 14m3)
The leak test pressure is 1485 psig
Nitrogen cylinder -> 6m3 / 2175.5psi
I’m struggling with the fact the bottles will begin to equalize with the test segment meaning it’s not as simple as I first thought. I believe I need to calculate how much gas is in a cylinder between the delivery and test pressure (useable volume)
Any help would be appreciated.
Many Thanks
#2 latexman
  • 1,812 posts
Posted 25 October 2024 - 04:16 AM
Don't colored your post, this makes the reading difficult.
Show/attach your work.  Have you tried the ideal gas law, PV = nRT?
#3 breizh
  • 6,715 posts
Posted 25 October 2024 - 06:13 AM
Hi, Pagi 'Bu
Agree with latexman , I did the calculation using the perfect law gas PV=nRT
My calculation is 3 full receivers of N2 and 32 %mass of the 4th one.
Calculation is based on initial condition vs final condition.
To visualize the process, consider a tank with N2 and the pipe, in between a valve (open or close) during the test leak.
My assumptions.
Isotherm process, Initial condition, pipe full of air at Patm , Air # N2 (no impact on the test).
driving force is the pressure meaning P bottle >or equal to Pressure in pipe .
At the end of each step, you have remaining product in the bottle!
End of the test when P= 1485 PSIg
#4 breizh
  • 6,715 posts
Posted 27 October 2024 - 04:45 AM
EDIT :
Right now I'm confused with the capacity of the nitrogen cylinder ....
Are you sure about 6 or 7 m3 ?
It seems that 1 cylinder is about 50 liters per unit at 145 bars equivalent to 7 m3 at 1 atm.
Please confirm your input.
https://survitecgrou...r_datasheet.pdf
With a 47 liters cylinder @ 151 bars A , you will need 343 cylinders to perform the test !
same methodology for the calculation, only volume of cylinder changes.
If confirmed , better to buy Skid or cage with 6 bottles per unit.
#5 breizh
  • 6,715 posts
Posted 28 October 2024 - 04:25 AM
No feedback from the OP!
