How Can I Simulate An Adsorption And Deoxidization Towers In Aspen Hys
#1 Ahmed.Loutfi
Ahmed.Loutfi
Posted 03 November 2024 - 09:00 AM
Hello, I am a mechanical engineer and new user with ASPEN and processes. I learned a lot of thing with ASPEN such as sizing a two phase separator and heat exchanger. I need all of that to make a purification system for green hydrogen production. So i need to make a simulation of drying adsorption tower using molecular sieve.
and i also need to simulate a tower using a platinum catalyst to deoxidization the oxygen in hydrogen stream.
  • 1,607 posts
Posted 04 November 2024 - 09:45 AM   Best Answer
Use the AspenPlus SEP block to specify the outlet stream with water removed. The SEP block may also be used for the deoxidation tower depending on your needs. The SEP block is a way to separate components when you know the composition answer already. The resulting stream can then be passed to downstream unit blocks while preserving the material balance. You will need to use other resources to answer design questions like 'how much mol sieve do I need?' or 'how much catalyst will I need?' For answers to questions like 'how much flow can I put through a deoxidization tower of specific diameter?' then the packed bed hydraulics found in the RadFrac column block might be useful. AspenPlus still won't answer such questions directly and you should use outside resources for guidance.
#3 shvet1
shvet1
  • 476 posts
Posted 04 November 2024 - 11:40 PM
A mech engineer and process modelling
Seems bad
Why have you taken this task up?
Edited by shvet1, 04 November 2024 - 11:45 PM.
