Heat Exchanger Steam Flow
Posted 25 November 2024 - 05:49 AM
The tube bundle was removed and found clean and the shell it self was clean
Any guess where the problem could be found
The reboiler using LP steam and heating sour water
Posted 25 November 2024 - 06:15 AM
Can you be more descriptive? "Having a problem" does not tell us much. Give the inlet and outlet data (T, P, flow rates), the heat exchanger specifications (tube size and length and number, heat exchange area, MAWPs, etc.), the heat duties, and exactly the physical parameter that is limited. How do you know the HX is not at it's physical limit?
Posted 25 November 2024 - 06:28 AM
a PID is appreciated, on top of Latexman's requests.
Is it a new problem?
Could be accumulation of inert, could be quality of the steam? should be saturated, could be an issue with level ....
Nothing wrong with your process???
Many things, in fact.
Posted 25 November 2024 - 04:03 PM
Actually I don't know how to add a PID here, for your question is it a new problem, yes it is
We used to feed to the column 39 m3/HR with approx 5000 kg/h steam
Now with control valve opening 100 % the steam flow is approx 4200 kg /HR , the steam is saturated, pressures 3.5 bar, temp 175 degree C
Edited by aliebrahem17, 25 November 2024 - 04:04 PM.
Posted 26 November 2024 - 07:56 AM
I can't find More in Reply button
When editing a post, you’ll see “Use Full Editor”. On a new post, you’ll see “More Reply Options”. Both give you the same functionality. The attachment functions are below the text box.
Open your eyes. Don't give up so easy.
#11
Posted 27 November 2024 - 07:33 PM
#12
Posted 15 March 2025 - 06:06 AM
What is the process outlet temp and steam pressure on the shell?
What is the FT span?
Did you verify field vs DCS position?
Did the process inlet temp change?
Condensate control loop functioning properly? Could you confirm shell isn’t backed up ?
Did the composition of process inlet stream change?
Process inlet stream phase composition change?
#13
Posted 13 April 2025 - 11:11 PM
Thank you breeizeh and latexman for your reply
Steam at 3.5 bar pressure and 175 C temperature is superheated, it is not saturated. There is poor heat transfer across reboiler, steamis blowing, no residence time. Adjust steam flow manually. Sour water stripper column water level must maitain. At 3.5 bar pressure saturated temperature should be 136.7C. Confirm reboiler water level is maintain. Usually sour water contains lot of sludges and impurities and frequent foulimg of reboiler is common. There might be a direct steam to Sour water stripper column in case you want to take reboier out of service. Are you maintin treated water quality?
I prefer to draw a sketch and upload for clear understanding.
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
