4
How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) Be
#1 tokotof
tokotof
Posted 29 November 2024 - 08:22 AM
I checkde with GPSA and Bryan Research and Engineering to model an amine sweetening process using Amdea (MDEA 45wt + PZ 5wt).
Instead of a trial-and-error approach, I am looking for an equation or method to preliminarily estimate the circulation rate before the detailed design phase.
I have seen preliminary circulation rate guidelines for MEA, MDEA, and DEA etc, in various references.
However, I am unsure how to approach this for Amdea.
Does anyone know how to estimate the preliminary circulation rate for this specific blend or have any references or methodologies for this?
Is the only way to estimate the flow rate just to input it into HYSYS and check the results?
If you could recommend any literature or articles, I would deeply appreciate it and read them thoroughly! I've been searching for this issue for a month now!
  • 1,552 posts
Posted 29 November 2024 - 08:48 AM   Best Answer
Circulation rate is calculated from the rich and lean compositions and the gas treatment requirements. This is just a material balance problem. Are you struggling with knowing the rich and lean compositions? Or the volume flow of gas? Or the composition of the inlet and outlet gas? The amine flow rate is the only unknown variable after these inputs are known.
#3 tokotof
tokotof
Posted 02 December 2024 - 06:04 PM
Ls = Gs*(YN+1-Y1)/(XN-X0)
Thanks to you i use this equation. whichi is
Gas Flowrate on Solute Free Basis [Gs]
+10%
-10%
ⓘ Solute Free Mole Fraction of Gas in Inlet [YN+1]
+10%
-10%
ⓘ Solute Free Mole Fraction of Gas in Outlet [Y1]
+10%
-10%
ⓘ Solute Free Mole Fraction of Liquid in Outlet [XN]
+10%
-10%
ⓘ Solute Free Mole Fraction of Liquid in Inlet [X0]
Thank you for your kind response. I am currently designing the process as follows. What I am struggling with is determining the appropriate values for ⓘ Solute Free Mole Fraction of Liquid in Outlet [XN] and Solute Free Mole Fraction of Liquid in Inlet [X0]. Is there a standard or guideline for these values? please  recomend any documents and books.. thanks
귀하의 안내 덕분에 현재 다음과 같이 프로세스를 설계하고 있습니다.
Edited by tokotof, 02 December 2024 - 06:04 PM.
#4 breizh
  • 6,714 posts
Posted 03 December 2024 - 07:00 AM
If I was in your shoes, I would try to find supplier of this chemicals on Internet. Then I will email or ring them to get data /brochures about the system AMDEA / gas to be treated. It's in their interest to share data to promote their solvent.
https://www.aidic.it...a/420etoumi.pdf
https://onepetro.org...DEA +piperazine
Part 1 – Estimation of Solubilities of Selected Hydrocarbon Compounds in Treating Solvents | Campbell Tip of the Month
#5 Dacs
Dacs
  • 457 posts
Posted 06 January 2025 - 12:54 AM
This is the answer.
You set the target lean and rich loading (mol H2S/mol aMDEA), set the target H2S content in sweet gas and everything will follow.
Practically speaking, rich amine loading will dictate your circulation rate as high values will require CRA materials in your rich amine section, due to increase in corrosivity.
But for your use case as a student, you can certainly follow what BR&E recommends for rich/lean amine loading. They make ProMax after all, the gold standard wrt to gas sweetening process, IMO.
I have seen lean and rich amine loading (for MDEA) at high as 0.1 and 0.81 mol H2S/mol MDEA, respectively.
Edited by Dacs, 06 January 2025 - 12:55 AM.
#6 _1angelia23
_1angelia23
  • 41 posts
Posted 10 January 2025 - 04:12 PM
You can see the equation in the link. It may help you
https://ibb.co/T283bWt
Edited by _1angelia23, 10 January 2025 - 05:03 PM.
#7 breizh
  • 6,714 posts
Posted 11 January 2025 - 02:10 AM
A Google search is your ultimate resource.
https://ou.edu/conte...and_l_kroop.pdf
