Gas-Liquid Separator Design With Condenser
#1 shambola
shambola
Posted 16 January 2025 - 07:51 PM
I was wondering how to start my design the first unit operation being a condenser to turn one gas into a liquid then using a gas-liquid separator to separate the components in the gas and liquid phase.
How do i start the design calculations.
And is there any design calculation excel spreadsheets I can use as a guidance
Kind Regards,
  • 7,027 posts
Posted 16 January 2025 - 09:46 PM
What do you mean?
" using a gas-liquid separator to separate the components in the gas and liquid phase".
A sketch will certainly help to understand your query.
#3 chemdoc
chemdoc
  • 28 posts
Posted 17 January 2025 - 02:13 AM
do you wish to solve from a thermodynamic point of view (i.e. solve a flash operation with specified enthalpy which provides the vapor + liquid at outlet) or try to simulate real units calculating heat transfer coefficients, separator efficiency etc. ? You can manage both cases with spreadsheets, I use the free version of Prode Prode Properties (www.prode.com) as thermo library , it includes some examples and you can add /expand features if required...
