Hello everyone,
How to define Chimney tray in HYSYS V12?
Posted 20 January 2025 - 09:47 AM
Hello everyone,
Posted 20 January 2025 - 04:58 PM
Hello everyone,
Chimney trays are not usually explicitly modelled in steady state simulations. Unless you are doing something unusual, just ignore it in the simulation.
Posted 20 January 2025 - 09:36 PM
Posted 21 January 2025 - 01:05 AM
Hello everyone,
And if I want to use Chimney tray in dynamic simulation?
Posted 21 January 2025 - 01:53 PM
A chimney tray will add a small amount of liquid holdup volume. The liquid holdup volume or holdup time should be available in the documents the designer supplied or you can calculate that yourself from the chimney tray dimensions. If you can build a dynamic simulation model where the chimney tray holdup is the only inaccuracy, you will be doing great!
Petrosim Tray SizingStarted by Guest_tomr91_* , 27 Feb 2025 |
Uniform Vs Non-Unfiorm Tray In HysysStarted by Guest_tomr91_* , 23 Jan 2025 |
![]() How Is The Performance Of The Distillation Tray Calculated? The DistanStarted by Guest_Ahmedforup_* , 11 Oct 2024 |
Flash Tower With Tray In Deoiling Of Wax?Started by Guest_AnbIran_* , 01 Jul 2024 |
![]() Sieve Tray Rating In Aspen PlusStarted by Guest_Root_* , 24 Sep 2023 |
