3
Physical Properties Of Liquid Discharge For Kod Sizing
#1 mahmooddalvi09
mahmooddalvi09
  • 21 posts
Posted 26 February 2025 - 03:20 AM
Hii,
I am preliminary sizing a KOD and as API 521 mentions, liquid discharge of 2% (wt/wt) of total design gas flow rate has to be considered if there is not any liquid relief for any PSV in the PSVs connected to flare . Now, i found gas/vapor properties (governing case) in HYSYS at min. superimposed backpressure. How shall i estimate properties (mainly density) of liquid that's been considered as 2% (wt/wt) of total gas flow? What will be composition of same?
Help is much appreciated.
  • 6,710 posts
Posted 26 February 2025 - 06:12 AM
Did you try a flash calculation using your simulator?
#3 Pilesar
  • 1,550 posts
Posted 26 February 2025 - 07:14 AM
What liquid could possibly be in the knock out drum? Just choose conservatively. Water? Oil? Does it matter? If the drum had a 3 NPS liquid nozzle, would that be large enough? Would a 2 NPS nozzle be large enough? I don't understand why not just pick a nozzle that is large enough and use it for preliminary sizing.
#4 mahmooddalvi09
mahmooddalvi09
  • 21 posts
Posted 27 February 2025 - 12:27 AM
Hii breizh,
Flash calculation at what conditions? I mean at min. superimposed bp and relieving temp there is no liquid relief as per simulator. There is no liquid as such at relief conditions.
#5 breizh
  • 6,710 posts
Posted 27 February 2025 - 12:51 AM
So, follow pilesar'recommendation.
#6 mahmooddalvi09
mahmooddalvi09
  • 21 posts
Posted 27 February 2025 - 01:06 AM
Hii pilesar,
Ammonia mostly. okay understood.
Thanks!
#7 breizh
  • 6,710 posts
Posted 27 February 2025 - 01:35 AM
Pay attention on how you want to dispose this hazardous material.
