3
Co2 And Mea Vle Data
aspen hysy
#1 Verdurer
Verdurer
Posted 24 March 2025 - 03:00 PM
Dear ladies and gentilemen,
Hi.I am an chemical enginnering student and I recently met some problems in my project of Amine scrubbing. As I am sizing the regenerator,which is assumed to be a distillation column in Aspen hysys, I should start by using some shortcut method such as mccabe thiele. And the xy-plot for CO2 and MEA seems like a mess. Thus, I stopped at the first step of internal sizing. I wonder what should I do to estimate the applicable VLE data.
Thank you
  • 1,552 posts
Posted 24 March 2025 - 08:23 PM
McCabe Thiele shortcut method is not appropriate for modeling CO2 removal using MEA as you found out. You should use a rigorous distillation model. There is an acid-base reaction taking place. Hysys should have a thermodynamic method specially for amines -- probably using the Kent Eisenberg approach to account for the reactions. For a primary amine such as MEA, this method gives good results. You model the regenerator in a rigorous column using the special amine package. The regenerator does not need many stages-- perhaps seven theoretical stages total. If you use too many stages, convergence can be more elusive. You will want a partial condenser. Do not concern yourself with sizing internals until after you get an accurate converged model.
#3 breizh
  • 6,714 posts
Posted 25 March 2025 - 01:48 AM
You may find pointers in the links attached.
https://www.aidic.it/cet/13/32/309.pdf
https://www.ijcce.ac...7001f296984.pdf
More info using your favorite search engine
key words: Kent Eisenberg CO2 MEA model
