4
Pressurizing Liquid
pressurized tank cstr centrifugal pump process engineering
13 replies to this topic
#1 Ahmadhamzahperta
Ahmadhamzahperta
  • 13 posts
Posted 02 April 2025 - 03:03 PM
Guys i have a basic question that have been bothering me for a while now.
I know that even tho liquids are considered as incompressible that doesn’t mean that it cant be pressurized. However im confused on how do we pressurize it in industry.
Lets say i have a CSTR operating at 5 bar and lets assume that both the producs and reactants are all stable liquid with low volatility. If the feed is supplied with centrifugal pump, at startup how will the reactor be pressurized?
Please consider two cases where air exist inside reactor and where the tank is in vacuum pre-start up
  • 6,778 posts
Posted 02 April 2025 - 05:37 PM
A better description is needed.
#3 Pilesar
  • 1,565 posts
Posted 02 April 2025 - 06:27 PM
If there is vapor and liquid both in the vessel, the pressure comes from the vapor. The vapor pushes against the inside walls of the vessel and against the liquid also. So the pressure of the vapor and liquid are very close to the same. There will be some gradual increase in pressure toward the bottom since the bottom will have the additional weight of the fluid above.
#4 shvet1
shvet1
  • 476 posts
Posted 02 April 2025 - 11:06 PM
You need to feed the reactor with a gas, e.g. a source of N2@10bar. The higher gas pressure, the sooner one will achieve the pressure swing.
And the liquids are compressible, google "liquids bulk modulus"
#5 breizh
  • 6,778 posts
Posted 03 April 2025 - 12:50 AM
A good start should be to give us the chemical reaction(s) together with the operating conditions.
Breizh.
#6 Ahmadhamzahperta
Ahmadhamzahperta
  • 13 posts
Posted 03 April 2025 - 02:24 AM
Is there any other way beside supplying N2 into the reactor? I always imagine that pump would be enough to somehow pressurize it
#7 Ahmadhamzahperta
Ahmadhamzahperta
  • 13 posts
Posted 03 April 2025 - 02:26 AM
If for example there is no vapor inside the reactor, could we still somehow pressurize it? Can pump alone pressurize it?
#8 Ahmadhamzahperta
Ahmadhamzahperta
  • 13 posts
Posted 03 April 2025 - 02:41 AM
Breizh.
I can’t think of any chemical reactions as it was only a hypothetical scenario. But if you’re concern is whether the reaction is exothermic or not lets ignore that for now and also lets assume that no vapor are generated. What i want to understand is how liquid vessel is usually pressurize. Do we supply high pressure gas? Or does pump somehow do the work?
#9 Ahmadhamzahperta
Ahmadhamzahperta
  • 13 posts
Posted 03 April 2025 - 02:43 AM
By the way thanks guys for the responds. Very much appreciate it :)
#10 breizh
  • 6,778 posts
Posted 03 April 2025 - 05:26 AM
Shvet1 gave you an answer, by adding Inert gas in the sky of the reactor.
Pumps are not going to add pressure; it's a transfer mean.
#11 shvet1
shvet1
  • 476 posts
Posted 03 April 2025 - 06:30 AM
Could, but those cases are irrelevant to the topic.
Given the reactor has a vapor-liquid interface, no, it can't.
#12 Ahmadhamzahperta
Ahmadhamzahperta
  • 13 posts
Posted 03 April 2025 - 12:11 PM
Ahhh i see, thanks a lot my friend
Edited by Ahmadhamzahperta, 03 April 2025 - 12:12 PM.
#13 shvet1
shvet1
  • 476 posts
Posted 03 April 2025 - 10:56 PM
Given the reactor total volume is 5m3 and is filled with air @1bara.
Assume it is filled with water and all outlet connections are closed and tight (no air leaks frm the reactor).
One pumps 4m3 of water to the reactor, reactor vapor space is displaced with water and shrinkes from 5m3 to (5-4)=1m3.
As there are no air leaks, air compessibility does not chang and ignoring the temp change and assuming Henry's constant = 0, the air mass is constant and the equation looks
P*V=m/M*Z*R*T
m1=m2
Z1=Z2
T1=T2
m1/M1*Z1*R*T1=m2/M2*Z2*R*T2
P1*V1=P2*V2
P2=P1*V1/V2= 1bara * 5m3 / 1m3 = 5bara
Ta-da, one has pressurized the vessel with water only. A middle school level task.
Are you looking for such explanation?
Edited by shvet1, 03 April 2025 - 11:06 PM.
#14 Ahmadhamzahperta
Ahmadhamzahperta
  • 13 posts
Posted 04 April 2025 - 09:42 AM
P*V=m/M*Z*R*T
m1=m2
Z1=Z2
T1=T2
P1*V1=P2*V2
Of course not, i was just wondering wheter its the pump or supply of high pressure air that are usually used in industry to pressurize a liquid vessel. So your previous have sufficed thank you
