2
Phosphoric Acid 56% Tank Lining
phosphoric acid storage tank rubber vinyl acid tank lining 56% insulation material
#1 Phosphoric123
Phosphoric123
Posted 20 April 2025 - 02:03 PM
Hello all,
Does anybody have experience in the interior lining of a carbon steel phosphoric acid storage tank?
Currently, we only use the carbon bricks + rubber lining solution, mostly chlorobutyl. Is there any other solution for example similar to novolac that has had good and long lasting results?
The fluorine in the acid is a little higher than normal as well.
Further to this, has anybody had experience with the insulation for the concrete foundation of the tank? Current system is rubber sheet with acid resistant bricks and furan mortar.
We currently are looking at this for a new 2000 ton storage tank.
Phosphoric acid
P2o5- 56%
F- 0.6%
Thanks very much guys, Any help would be greatly appreciated.
  • 6,715 posts
Posted 20 April 2025 - 06:06 PM
Consider this resource.
Another option could be to ring or email suppliers of Phosphoric acid.
My experience with this product, small storage tank, is stainless steel 316 L. It was used as a catalyst (high quality phosphoric acid).
Note: You may want to contact Sulzer, they are offering agitator for phosphoric acid storage tank:
https://www.sulzer.c...i_en_a10084.pdf
EDIT: Considering the size of the tank I will go for bricks, staying on the conservative side.
Exotic materials should be very expensive.
https://wyrenteco.en...orage-Tank.html
Good luck,
