4
Gas-Liquid Pipe Flow Friction Loss Correction
pipe flow condensation pressure drop
#1 Huba
Huba
  • 16 posts
Posted 18 December 2025 - 11:31 AM
Hi all,
I need to calculate the pressure drop for a biogas pipeline. The biogas is produced from a digester plant, so will be saturated with moisture. I assume the moisture will condensate in the pipe run, and will add into the friction losses.
I looked up the Lockhart-Martinelli correlation for gas-liquid flow, which adds a correction factor (theta):
DeltaP_2phase = (theta^2) * DeltaP_gasonly
theta^2 = 1 + C/X + 1/X^2
X is the Lockhart-Martinelli parameter
X = sqrt (deltaP_liq / deltaP_gas)
1) To calculate the liquid pressure drop, how can i estimate the condensate phase velocity?
2) Is it possible to simplfiy, by estimating the correction factor? According to Copilot, 1.2 - 1.5 is a good ballpark...
Thanks,
  • 1,609 posts
Posted 18 December 2025 - 02:13 PM
Pressure? Line size? Line Length? Elevation changes? Fluid quantity? Why not condense and dry before entering pipeline? Why not trap liquid out of the pipeline? Most pipelines of any appreciable length are not completely horizontal. Will liquid just collect and sit in the low spots?
#3 breizh
  • 6,887 posts
Posted 18 December 2025 - 04:45 PM
Take a look at these links:
moisture in biogas
Avoid moisture problems in your biogas plant.
In addition, you will find a set of equations for different models used for 2 phase flows.
#4 carlos infante
carlos infante
  • 24 posts
Posted 20 December 2025 - 11:01 AM
The first thing to consider is to find if the moisture condenses at the process conditions.
Carlos
