I'm neck deep in my final design project for my course, and I'm discovering that there are many things a chemical engineer needs to know that we weren't taught in class. One of these things is how to figure out where to put relief valves on a compressor, and what size they should be.
The compressor in question is a four stage centrifugal compressor that takes a 3:1 hydrogen to nitrogen feed (with 1% argon) at 50 bar and 25 oC and compresses it to 190 bars before it enters the ammonia synthesis reactors.
The first three stages compress 2.6 kmol/s of gas to 180 bar, so each stage has a compression ratio of 1.53. In the fourth stage, a flow of 5.4 kmol/s recycled synthesis gas enters (also at 180 bar) for a combined total of 8 kmol/s of gas being compressed to 190 bars.
There is an inter-cooler after each of the first three stages that returns the temperature of the gas from ~81oC back down to 25oC
I hope that is enough background on the compressor to help answer some of my questions.
I've been told I need a PSV after the third stage, and I'm starting to assume I will probably need one after the 4th stage too. However, (this is more for my own general knowledge than about this compressor) how do you tell when and where you need a PSV?
The real heart of this problem is I don't know what the criteria are for designing a PSV. From reading this site this afternoon, I know it has something to do with the maximum allowable working pressure of the compressor, but I don't know how to calculate that number.
And, as if that weren't enough
Thanks in advance for any help, or pointers in the right direction you can give me.
Rob.
