Many literature of equipment sizing to remove oil in water (produce water treatment) use stokes law (Gravity Setling, CPI Separator, etc). The calculation basis is the droplet size (in micron). But the actual design requirement is the final oil content (in ppm).
How to translate ppm requirement to droplet size? Do we have to make laboratory test to make corelation of micron vs ppm? Or Has somebody simplified it in an equation/table/diagram?
Rgds,
MNG
Micron Vs Ppm
Started by muchlis nugroho, Apr 25 2007 11:05 PM
Posted 25 April 2007 - 11:05 PM
Posted 13 June 2007 - 09:21 AM
Hi Much,
Any vendor supplying coalescers will not guarantee the performance on absolute basis (ppm) but on size basis (micron) because the particle size distribution is generally unknown. The client has to determine the particle size distribution in the inlet liquid and supply to the vendor. The vendor then calculates the particle size distribution at the outlet of the coalescer and convert to absolute terms (ppm) by mass balance.
Regards.
Regards.
Achieve 5 Micron PowderStarted by Guest_chiragpatel_* , 10 Sep 2016 |
Verfy Micron SizeStarted by Guest_mohanrao914_* , 02 Aug 2015 |
