I have project to install new vent stack to release steam from steam PSV's and to release hydrocarbon from production line PSV's. Of course the stack will working intermittently, only when the PSV's popping. The vent line for each fluid (steam and HC's) is coming into different nozzle on the vent stack. My question is .. how to determine required vent stack height and diameter, because in this case we have two different fluid to be released, and the probability to released it at the same time nearly zero. As we know together, that steam is harmless and not flammable, what is design criteria to design vent stack for this case? I've read API 521, and my conclusion is to size diameter of the stack is to meet max Ma number = 0.5, but I've no clue about the required height calculation, because in my opinion we don't need to dispersed the fluid with air. But how about the HC's? to be honest, I still not clear yet how to use fig 3 (the figure X = velocity ratio, Y = vertical plume distance factor) in API 521 RP for calculating vent stack height..? on code it said, to get well dispersed vent gas, the height needed is around 120 Diameter vent stack? Is the reference for 120 D is from the ground? or for calculating vent stack height we need to simulate using Gauss equation?
And last question, what is the criteria to choose whether we have to use flare stack rather than vent stack, if the case is about LHV, what is minimum LHV to determine we have to use flare stack to dispose the vent gas..?
thanks a lot for your input
