Flowmeter Type In Flare Gas Header
Started by ankur2061, Aug 07 2007 10:46 AM
9 replies to this topic
Posted 07 August 2007 - 10:46 AM
Earlier practice for measuring gas flow in pipeline has been to use thermal mass flow meters and turbine meters.
However, there is an increasing shift towards using ultrasonic flow meters.
Is there a particular reason for it? What accuracies and turndowns are we talking about when using ultrasonic flowmeters? What are the economics vis-a-vis thermal and turbine meters?
Why would flare gas measurement require an ultrasonic flowmeter? Is it now mandatory in the U.S.and EU to measure and keep records of flaring and venting? Do any international standards give any guidelines about flare gas measurement and monitoring?
Guys, so many questions. Just hope somebody could answer.
cheers
ankur2061
cheers
ankur2061
Posted 07 August 2007 - 01:22 PM
QUOTE (ankur2061 @ Aug 7 2007, 10:46 AM) <{POST_SNAPBACK}>
Some opinions...
Ultra sonic flowmeter has the following benefits / advantages compare to other type of flowmeters ;
- Low TURNDOWN (can be as low as 2750-to-1)
- "Zero" pressure drop)
- No internal, insertion and moving parts
- Can tolerate certain amount of condensed liquid
- Take higher operating temperature **
- Not affected by gas composition
- No maintenance
** My personal experience upto 260 degC.
Read the following basically answer most of your queries.
- The Future of Flare Gas Measurement
- How much do you flare? How to measure flowrates of flare gas accurately and reliably.
- Use Ultra-Sonic Flowmeter in FLARE Gas Header for emission monitoring
JoeWong
Posted 07 August 2007 - 02:31 PM
Thanks for the links, Joe; really interesting materials.
Flowcontrolnetwork has a bunch of wide-subject literature available online.
http://www.flowcontr...om/magazine.asp
Posted 07 August 2007 - 04:15 PM
Ultrasonic flow meters are not reliable.
Posted 07 August 2007 - 08:30 PM
As highlighted by (sorry, can't find the earlier post), heat tracing may affect measurement of Ultra-Sonic flowmeter.
JoeWong
JoeWong
Posted 07 August 2007 - 11:27 PM
Hi Joe,
Thanks for all the input. It is really good stuff.
One more question!
What are the regulatory guidelines for flare gas measurement given by regulatory bodies like EPA and others (I don't know which is applicable in EU), if any?
One more question!
Posted 09 August 2007 - 05:29 AM
QUOTE (ankur2061 @ Aug 7 2007, 11:27 PM) <{POST_SNAPBACK}>
Hi Joe,
One more question!
One more question!
ankur2061
Can't help you much other than advise you to find those information in the following Links...If you are kind enough, once you have answer to your questions, please post them here for the benefits of all.
Lets learn together...leaning is continuous process in life.
JoeWong
Posted 10 August 2007 - 04:45 AM
Preferrably, the flow measurement device for flare gas header is a non-intrusive type. The last thing you want in your flare / vent system is some obstruction or blockage in the header or pipe.
I can't comment on how reliable an ultrasonic meter is, but at the very least, if there is a need to replace, maintain or repair anything with the measurement device, you can proceed without shutting down the flare system, or as a matter of fact the whole plant.
Guest_vklearner_*
Posted 25 August 2009 - 02:34 AM
Ultrasonic flowmeters are more costly as compared to thermal ones. thermal flowmeters are accurate over a small range . ultrasonics have a wider range... flare wd genrally require a flowmeter just to see whther a flow is happenin or not. one may not be too concerned abt the quantum of flow in some situations.. therefor thermal flowmeters may be a chaeper option for certain applications though an ultrasonic flowmeter is a more comprehensive (but costlier) solution.
#10
Posted 01 September 2009 - 10:42 AM
In my experience ultrasonic flowmeters are not too accurate at the low pressures involved in flare systems. You need at least 5 bar to get an accurate reading.
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
