why is throttling using a control valve an isoenthalpic process? how is this different from throttling using an orifice?
Isentropic Vs Isenthalpic
Started by Surirama, Sep 09 2007 10:30 PM
Posted 09 September 2007 - 10:30 PM
Posted 10 September 2007 - 12:41 AM
Surirama,
The term used shall be isenthalpic process instead of "isoenthalpic process"
Throttling through a control valve is a quick process involve change in state but no energy be in the form of work or heat is exchanged with the environment. Those it is commonly accepted as isenthalpic process.
You may view a control valve as a device with changeable orifice. Thus, there is no different between them.
Please also read the following...HERE 1, HERE 2, HERE 3, HERE 4
Other CheJedi, please assist further...
JoeWong
JoeWong
Posted 10 September 2007 - 08:22 PM
[quote name='JoeWong' date='Sep 10 2007, 01:41 AM' post='12812']
Surirama,
JoeWong
[/quote
Hi Joe,
Much appreciate your reply...However, I did have another question.
Consider a steam turbine. Steam passes from the steam chest to the turbine case via a nozzle where it impinges on the impeller blades. Would the change in flow variables in this case be small and gradual (big steam chest, small nozzle, big impeller casing - the flow area changes drastically) and would this be considered an isentropic process?
Cheers,
Surirama
Surirama,
JoeWong
[/quote
Hi Joe,
Cheers,
Surirama
Posted 10 September 2007 - 10:26 PM
QUOTE
Surirama,
An IDEAL steam turbine will goes through isentropic process. In REAL world, NO one steam turbine is isentropic. Thus isentropic efficiency come in picture to take care the deviation of a REAL from IDEAL steam turbine.
Please read more...STEAM Turbine
JoeWong
Isenthalpic Throttling With Flashing LiquidStarted by Guest_lofarcio_* , 06 May 2022 |
Isenthalpic Expansion Valve CalculationStarted by Guest_Bitan729_* , 13 Sep 2021 |
![]() Isentropic Efficiency Compressor And TurbineStarted by Guest_panoskagiou_* , 15 Feb 2020 |
Direct Intergration Of Isentropic Nozzle FlowStarted by Guest_Sara Owens_* , 19 Mar 2019 |
Calculation Of Thermodynamic Properties For Isentropic CompressorStarted by Guest_Matt93_* , 08 Sep 2017 |
