I would request some of learned and senior colleagues to give me some background on drain systems in an oil and gas installation, both onshore and offshore.
Follwing are the questions:
a) Can an open drain system be connected to a closed drain system? To my undertsanding this is not permissible in new installations as per several operating company guidelines. However, there may be extreme circumstances where due to equipment/piping layout constraints and process requirements it may be required to do so. Process requirements mean where the hydrocarbons removed from the open drain collection vessel and the closed drain vessel have a common end destination.
If this is permissible, what are the design constraints that need to be considered when connecting open drains to closed drains?
c) Is there a classification methodology / heirarchy of drain systems such as open/closed, hazardous/non-hazardous, oil-contaminated/relatively oil free/completely oil free in oil and gas installations. If yes, can the heirarchy be represented as a diagram or sketch?
Would appreciate a lot if some of the learned veterans of this forum could answer my questions or at least direct me to some literature/article/standard which would answer all of the above questions.
ankur2061
