Posted 27 September 2007 - 04:10 PM
Ankur:
Once again, I stress the importance of noting that API 14E is a RECOMMENDATION. It is not a design basis and much less a standard, rule, or mandate. If you (or others – such as Mr. Salamah) can come up with the correct “c” value that will yield an acceptable, cheap, durable, and safe pipe size than it should be published and followed. However, as you and most of us know, that will never be the case since no one in his/her right mind is going to undertake the time and expense to field test every conceivable combination of oil, water, gas, sand, and dirt in order to generate the “correct” answer and donate it to humankind. It just isn’t going to happen.
In fact, in all of my professional years designing and operating equipment I have never heard or seen a design that ensures that the assumed quantity, flowrate, and type of sand mixed with the crude oil will always be constant. What happens in reality is that sand travels as a semi-slug! It gushes through sometimes; at other times, it settles as it forms deposits. As the deposit increases, the pipe cross-section decreases and the resulting velocity INCREASES – entraining and slugging through the sand that had previously settled. And this goes on, and on, and on ……. So what is going to be the design figure or criteria for the sand proportion in the equation to be used? The worst case, of course. And this is what, unfortunately, the API has had to confront. That is why the result is a conservative answer – and thank God for that. No one to date has come up with a more logical manner of establishing a design procedure for handling this type of fluid flow. And I don’t see anyone forming lines to establish a design equation that they will guarantee the results as being “accurate”.
I respect your client’s desire to obtain a more accurate answer (in order to save capital piping money), but if there are “more appropriate "C" values” out there in process design land, I wish they were identified and labeled as such (with guarantees) so that we could all use them. I don’t think that is the case, unfortunately. Therefore, that is why we all seem to be forced to follow API 14E recommendations. I really wish I could generate a more optimistic and hopeful answer on this subject.
