Centrifugal Compressor-inlet Guide Vanes
No replies to this topic
#1 Guest_Pankaj Wani_*
Guest_Pankaj Wani_*
  • guestGuests
Posted 28 September 2007 - 06:41 AM
Hi All,
I am working on a centrifugal compressor design.But I dont have any prior experience of doing this & nobody here have any idea abt this.
So Using CFD I am testing my models performance.
Not getting much/reliable literature on net.
Still I have been through Impeller and Low solidity Diffuser.
My next step is to add Inlet Guide Vanes,and as per theories we have to give some tangential component to the axial velocity to induce preswirl.
Now my question is that whether this is going to boost the efficiency,or they are only for capacity control to avoid surge?
What should be my aim to add them?
and how should i use CFD for their performance analysis?
I think I should get much more replies as there are too many experienced peoples in the forum.
So pls help me out.
Thanks and Regards,
Pankaj.
Posted 29 September 2007 - 10:43 AM
Pankaj:
Please do not post multiple copies of your query in other Forums. This is very distracting and confuses everyone about just which thread to respond to. It is very unproductive and creates chaos.
You say you are working on a centrifugal compressor design, although you don't have any prior experience of doing this. Additionally, you state that nobody around you has any idea about the subject. Allow me to ask why you, an inexperienced engineer, are doing this and for what purpose? Your product will undoubtedly be under scrutiny – even by yourself. So, why go through this exercise without any local guidance, mentorship, instruction, and leadership? If this is an industrial application, it is not logical.
The use of Computational Fuid Dynamics (CFD) is impressive – from an academic point of view. But what does that do to the credibility of the produced results? At best, CFD is a theoretical number crunching and developmental tool. But it is always subject to confirmation with actual field tests. Without the expensive confirming field and lab tests, the results are not credible.
Why don’t you do what we all do: fill in a Specification Sheet and submit it to a recognized, experienced, and proven designer and fabricator of centrifugal compressors for a quote?
If you think you have problems with the inlet guide vanes, wait until you get to the diffuser section. And you haven’t yet gotten to the control problem due to the potential surges your product will be subject to. And the required seals are another formidable problem. You will have to produce reliable, credible performance curves for your compressor and you will have to back them up with substantial guarantees. I assume you have the capital monies to finance all these requirements because potential buyers will immediately require that.
I've installed and operated many centrifugal compressors and labored with maintaining them on line and free from surges. It is very difficult for me to imagine that someone who has no prior experience can "develop" a credible, working, acceptable model - with or without CFD.
But I wish you a lot of luck.
#3 Guest_Pankaj Wani_*
Guest_Pankaj Wani_*
  • guestGuests
Posted 30 September 2007 - 02:51 AM
'Dear Mr.Art Montemayor'
Thanks for the reply.
Apologies for multiple postings.
Now to the point,we have queries send to many peoples for our application,which is diff than air.
We are in another field of process equipments but not rotary.
Now with our sytem we wre going to give customers this additional unit at an xtra cost which is affordable to them.Many will not invest for capitals unless and untill we will have a prototype at lowest possible cost,thats why we decided to develope one which will be in the budget and we r going to invest on prototype.
So with some process and mechanical anlysis through CFD & FEA we arrived at one size,decided all other things.This development will take more than a yr,but is within our expectations.
Now somebody has to start,then why not me?we r perticular to our product only and are not interested in other commpressors.
Now what is bad in doing this?
I will be glad if u can suggest any perticular reference book for this.
And as my earlier post I have asked abt inlet guide vanes,could u pls help me in that matter?
Thanks a lot for your interest.
#4 Art Montemayor
Posted 30 September 2007 - 09:35 AM
Pankaj:
Although you don’t identify your location, I believe you to be in a developing country and seeking to start your own centrifugal compressor industry. I think that is admirable and I commend you for the effort. That is one of the reasons for responding to your requests. Now to the points you’ve raised:
  1. You now reveal you are trying to develop your own product to compete with the existing major manufacturers. This is good, as I said, but I believe you are going about it in a wrong manner in order to be successful. You are not about to succeed when you haven’t designed and much less built a unit on your own. You need to accumulate the existing expertise and experience – at the very least. The way to go about that is to work directly in the industry and “get your hands dirty” by actively designing and fabricating these compressors. For example, get a job working for Alfa-Laval for about 5 – 10 years and learn how they design and build their machines. Without experience such as this, you have little chance for success. You are not going to find the experience and expertise for free in Internet Engineering Forums. Fabricators and designers are not going to give you (for free) the information and expertise that it cost them years and investments to obtain. That’s my answer to your first point.
  2. There is nothing “bad” in doing what you are attempting; I think I have been clear in describing this as a good – not a bad thing. To presume that others take what you are doing as “bad” is a rash and immature attitude. I don’t think you mean it that way, but that’s the way it is interpreted.
  3. The real, substantial source of credible and proven technology for centrifugal compressors lies in the centrifugal compressor design and fabrication field. Most of the conventional compressors have already been designed. I don’t think your application is so novel or unique that it hasn’t been designed for and modeled yet. If your application is indeed unique, then it will be limited in the number of fabricated units required; and if that is the case, the unit Capital Cost will be much higher than for existing, proven, “on-the-shelf” designs.
Explaining how a proper suction inlet guide vane should be designed and built on an Engineering Forum entails not only some liability, but a lot of faith. First, and foremost, information involving existing centrifugal compressors is, as I explained, PROPRIATARY. To divulge or sell this information is contrary to engineering ethics and, in most countries, to the existing laws. That’s why, as I stated, the fastest and most efficient manner of getting indoctrinated and experienced in the industry is to actually get involved in it as an employee. You will be required to sign the usual documents which limit you in competing with your employer for some future years, but after that you are free to use the information you have accumulated – as a consultant or a competitor.
I wish you luck.
#5 Guest_Pankaj Wani_*
Guest_Pankaj Wani_*
  • guestGuests
Posted 30 September 2007 - 11:32 PM
Thanks a Lot Mr Art,
This is really interesting to even read.
Really appreciable post.
But I dont want anyone to feed me with spoons.
I have been asigned a task,as many peoples did it without any background,I have a lot background.
But there are some references which really proves wrong to anothers,which increased my confusion
abt that perticular point,so i was expecting a point which could prove anyone of it to be correct.
I got it in another references.and as we have decided we will do it.Becoz our theorotical design expectations matching our cfd,fea results with all probabilities tried already.Right now working on some coz and corns to make it a final deal.And i said earlier we r not going to compete anyone but
this is almost another purpose not too unique but still different.
Thanks alot for your help.
Still will ask u abt one perticular genuine book reference.
