Vent Pipe Diameter Sizing
#1 asade abiodun
asade abiodun
  • 146 posts
Posted 10 October 2007 - 10:40 AM
Please can anyone help me with information on how to determine the pipe diameter for vent.
I have used API 2000 to determine the vent requirement for my tank. Its an atmospheric tank.
regards
#2 latexman
  • 1,810 posts
Posted 10 October 2007 - 11:45 AM
Please refer to Crane Technical Paper 410. It is considered one of the best references on how to apply fluid mechanics to non-complicated situations. It can be purchased online at www.flowoffluids.com That website was down when I just looked, hopefully only temporarily.
#3 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 10 October 2007 - 11:46 AM
Dear Asade Abiodun,
I am giving the link here below where the same thread is discussed and it has reply of our respected
chemical engineers GURU ......Mr Art Montemayer.
http://www.eng-tips....d=151637&page=1
http://www.eng-tips....d...967&page=10
http://www.protectos...m/ventrain.html
http://www.gjerde.com/services.htm
Padmakar Katre
#4 JEBradley
JEBradley
  • 126 posts
Posted 11 October 2007 - 06:17 AM
If this is just a straightforward vent and not an emergency vent (so we arent talking PSVs and bursting discs)... AND the chemical is safe....then Ive always used the rule of thumb that the vent line should be twice the diameter of the feed line. This is obviously assuming a single feed. You can extrapolate this to:
Vent Area = 2 x Feed Area.
#5 latexman
  • 1,810 posts
Posted 11 October 2007 - 07:13 AM
QUOTE (JEBradley @ Oct 11 2007, 06:17 AM) <{POST_SNAPBACK}>
If vent diameter = 2 x feed diameter, then vent area = 4 x feed area.
#6 JEBradley
JEBradley
  • 126 posts
Posted 11 October 2007 - 09:40 AM
It is only a vague heuristical technique - don't use it if you have some exotic system or weird chemical.
....But do go ahead and use it if you have a water storage tank (warning - put some kind of filter on the top of the vent line to stop dead rats falling in!!)
Thanks for pointing out my mistake btw - and its caused me to realise it a mistake ive followed through into practice. I had a tank filling from a 3" line which originally had a 6" vent. A later mod. caused by space limitations made me exchange it for 2-off 3" lines. Ive only just realised that doesn't add up smile.gif
