Calculation
#1 Guest_scorer_*
Guest_scorer_*
  • guestGuests
Posted 15 January 2004 - 06:42 AM
I have been looking at the experienced-based rules of chemical engineering article on the web site. Section G under Drum type vessels gives an equation for gas-liquid separators. It shows a term (vapour density -1). Should this be (vapour density). Should the minus 1 term be there? Thank you for any assistance.
#2 gvdlans
gvdlans
  • 619 posts
Posted 15 January 2004 - 08:27 AM
I agree that there is a mistake in there. The Souders-Brown equation reads:
velocity = k ((liquid density-vapor density)/vapor density)^0.5 (Equation 1)
which can be rewritten as:
velocity = k (liquid density/vapor density-1)^0.5 (Equation 2)
Which is not the same as what is shown in the experienced based rules:
velocity = k (liquid density/(vapor density-1))^0.5 (Equation 3)
(look at the location of the parenthesis!)
Since normally liquid density>>vapor density, equation (1) can be simplified to:
velocity = k (liquid density/vapor density)^0.5 (Equation 4)
Since the experienced bases rules are meant to use simple forms of equations, I would recommend to use equation (4).
A derivation of the Souders-Brown equation is given in Derivation of Souders Brown equation
#3 mbeychok
mbeychok
  • 364 posts
Posted 15 January 2004 - 11:58 AM
TO: gvdlans
QUOTE
Your are correct in saying that your Equation 1 can be re-written as Equation 2, but your Equation 2 can still be mis-interpreted. It still needs another set of brackets as follows:
velocity = ((liquid density/vapor density) - 1)^0.5
#4 gvdlans
gvdlans
  • 619 posts
Posted 15 January 2004 - 12:37 PM
To mbeychok:
Didn't we all learn at primary school the basic math rule that you have to divide before you subtract? Please Excuse My Dear Aunt Sally?! For those who do not remember, please have a look at Math Mojo!
You only use parenthesis in case you want to deviate from this basic rule. Since I did not want to deviate from the basic rule, I did not use parenthesis. wink.gif
#5 mbeychok
mbeychok
  • 364 posts
Posted 15 January 2004 - 01:02 PM
TO: gvdlans
My only rule is to write equations so that they cannot be misinterpreted ... if that is at all possible. Keep in mind that many readers may never have heard of any rules regarding the precedence of math operations. smile.gif
