Design Of Steam Drum
#1 wamit
wamit
  • 12 posts
Posted 24 October 2007 - 08:50 PM
Dear all,
I have been given a task to provide a preliminary steam drum size (diameter and tangent length).
The only parameters i have is 43.5 Barg @ 258 Deg C , 14000 kg/hr saturated steam is to be produced , using the heat from the flue gases of the fired heaters.
The BFW flow is 19.4 m3/hr.The vessel residence time is 10 min.
I would apprecaite if some one could guide me through the calculations
With warm Regards,
Amit
#2 JEBradley
JEBradley
  • 126 posts
Posted 26 October 2007 - 08:01 AM
I think you maybe need to go away to get a bit more information.
I think there's still a lot you can do with the figures though:
You know you're generating saturated steam at 43.5 bar. Check your steam tables to find the enthalpy change of vaporisation - I got 1685 kJ/kg. If you multiply this by the production rate of 14000 kg/h you should get about 23 600 000 kJ/h or 6.55 MW (Pretty high!!)
What temperature does the water start at? Ive neglected all sensible heat because it will be small compared to the latent heat - but find this out anyway.
I dont know what BFW is???? but i guessed it's maybe the flue gases????
I did a couple of extra calcs. - these are all just estimates because i dont have the info but it might give you an idea.
Using Q=UAΔT Lets say U=200 Wm-1K-1 which should be easily achievable; Q is 6.55x106 A=? and ΔT is unknown but lets say the gas is about 600 so call the ΔT=300K
Re-arranging and solving, A turns out to be about 100m2
This seems to be a lot to me so start asking yourself some questions - is the steam production really that high? What is the heat transfer arrangement - I have no idea, could be flue gases running through the drum as an internal coil or maybe the gases pass directly over it??? A well designed heat exchanger could potentially reduce the size 10-fold.
Im confused by the residence time - if thats referring to the 19.4m3 /h then the volume is only 3.2m3 - actually this sounds normal now (but not for the amount of heat that needs transferring).
#3 wamit
wamit
  • 12 posts
Posted 28 October 2007 - 09:55 PM
Dear Sir,
Thank you For all the inputs.
With reference to the above inputs given .
Yes the steam make is 14000 kg/hr.
The BFW is at 158 Deg C which gets heated in the economiser section of the heater (Stack)to 258.1 Deg C.
The residence time is 10 min of rth vessel.
With warm Regards,
Amit
