Positive Displacement Pump In Series With A Centrifugal Pump
Posted 04 December 2007 - 10:09 PM
I have across a situtaion whereby i need to size and specify a positive displacement pump as a booster to a centrifugal pump(in the downstream of the centrifugal).
I have the following doubts:
1)What type of control system should i give to maintain a constant flow from the centrifugal pump?
2)If somehow my centrifugal pumps less flowrate than the rated capacity of the PD pump,what is the consequence?Will it happen?What can i do to avoid this?
3)If the discharge of the PD pump is closed,should i trip the centrifugal pump?
Thank you
Vinod
Posted 05 December 2007 - 01:48 AM
Just wants to see if the combination is good before going into detail.
JoeWong
Posted 05 December 2007 - 02:18 AM
The servive fluid is a polyol...........viscoity is almost 400 cp........................
Posted 05 December 2007 - 06:23 AM
You will need to give a lot more information/details before any of us can give you any better guidance.
Posted 05 December 2007 - 10:54 AM
Let me clear you first the purpose of the booster pump is to provide the NPSH required/incresed suction pressure for the second pump.I have never seen this kind of combination rather you go for the two centrifugal pumps one as booster pump with low TDH and the second one as your main pump.
The way you asked this question its more of confusing to the readers.The three questions/doubts you have asked at the end of your query are really very hard to understand to me personally.
In your third query you ahve asked about closing the PD pump discharge what would be the consequence on the Centrifugal pump , forget about this consequence you will damage your PD pump by closing its discharge.
If you can present a schematic drawing of the same with some information like normal flows,pressures at different points (suction pressures,discharge pressures of the pumps), service and the temperature may we can give you some ideas.
Waiting for your reply.
Posted 05 December 2007 - 11:11 PM
My client wants the existing centrifugal pump rto be there ,and since he is planning to pump to a new destination,the fluid being very viscous is not reaching the destination,so he wants to boost it with a PD pump.
While i close the discharge of the PD pump ,i will put a recylce line with a PCV to ensure that the PD pump and the line blocked is not damaged.
The flow required is about 50 m3/hr and the head required is almost 200 m.
Please advise on the control schemes required.
Thank you
Vinod
Posted 06 December 2007 - 12:41 AM
Thank you
Vinod
What do you think if you put PD pump at centrifugal pump discharge ?
JoeWong
Posted 06 December 2007 - 01:20 AM
I am junior engineer and this is the first i am coming across such a case.
As far as i know,i will have to ensure a constant flow from the centrifugal pump to the PD pump(as it has a single rated discahrge asssuming it to be running at a single speed).
And that i have to maintain an NPSH for the PD pump(including the acceleration head).
Also that i need to provide a safety valve in the discharge of the PD pump,and arecycle line with PCV connecting back to the suction tank.
Please help me out
Thank you
Vinod
Posted 06 December 2007 - 06:11 AM
One possible way to get this to work would be to revise the piping so the centrifugal pump goes into a circulation loop and the feed to the PD pump is taken from that loop. You would/should recirculate th flow of the centrifugal pump back to the source. I'm not saying this is practical for your installation because I don't see your details but this is one way to simplify the control.
#10
Posted 06 December 2007 - 06:31 AM
Thank you
Vinod
#11
Posted 06 December 2007 - 12:03 PM
The best way to control the flow is via speed or stroke length (for those that operate via some piston type of capability). You can use a flow meter and control valve but the design must be more carefully thought out and postion of these devices is more important than they are for centrifugal pumps.
A centrifugal pump is NOT a constant volume device but will change flow with line/sytem pressure changes. Therefore, it is not a good idea to mix the two. Your safety issues are more complicated as will your ability to maintain a good control point to operate at.
#12
Posted 12 December 2007 - 10:52 AM
HTH,
Doug
#13
Posted 12 December 2007 - 11:57 AM
Good explanation...
Doug,
Looks unusual arrangement but may work if properly engineered.
Agreed that providing a dampener at recip. pump discharge may help to dampen the fluctuation but not sure the dampener performance with centrifugal pump downstream...i guess it still works.
Vinod,
Personally my first concern is the NPSHr of the recip. pump. There is acceleration head associate with recip. pump which significant increases the NPSHr for recip. pump. From NPSH perspective, i would think to locate the centrifugal pump first, follow by recip. pump.
Secondly, the centrifugal pump is existing. I presume it works well with existing condition without NPSH issue. Now with new condition (pump to new destination), i presume the head is insufficient. I would think we should locate the recip. pump downstream of existing centrifugal pump. This will not affect the existing arrangement and yet the centrifugal pump will provide necessary NPSHr for the new recip. pump. More over, recip. pump can provide a constant flow to "new destination.".
JoeWong
#14
Posted 13 December 2007 - 06:54 AM
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
Esp Or Sro PumpStarted by Guest_sima-f_* , 05 Jan 2025 |
