Isentropic Or Isenthalpic
Started by vinod, Dec 27 2007 11:32 PM
7 replies to this topic
Posted 27 December 2007 - 11:32 PM
Sir......
Is the expansion of a compressible fluid through a control valve an isentropic process or isenthalpic process and why?
Vinod
Vinod
Posted 28 December 2007 - 04:06 AM
QUOTE (vinod @ Dec 27 2007, 11:32 PM) <{POST_SNAPBACK}>
Sir......
Vinod
Vinod
Vinod,
Isenthalpic...
Read more in
Posted 28 December 2007 - 04:49 AM
Okay thank you sir........
But in these cases there will be the loss due to friction(drop in enthalpy),so where is this drop in energy accounted.
Is there any difference in the flow from a nozzle and across an orifice?
Vinod
Vinod
Posted 28 December 2007 - 08:05 AM
Vinod,
In a throttling process (control valve, nozzle or orifice) overall process is isenthalpic. However, the isentropic process occurs during a short period of time.
Using as example the steam expansion through a control valve orifice. For the steam to squeeze through the narrow restriction it has to accelerate to a higher speed. It does so by borrowing energy from its enthalpy and converting it to kinetic energy. This incurs a heat drop. This part of the process is isentropic. Having passed through the narrow restriction, the steam expands into the lower pressure region in the valve outlet, and eventually decelerates as the volume of the valve body increases to connect to the downstream pipe. This fall in velocity requires a reduction in kinetic energy which is mostly re-converted back into heat and re-absorbed by the steam. The heat drop that caused the initial increase in kinetic energy is reclaimed (except for a small portion lost due to the effects of friction). Therefore, the final process is isenthalpic.
Even so, the isentropic process occurs during a short period of time, it must not be ignored. The isentropic process leads to a decreasing in the fluid temperature. For example, a PSV or pressure reduction valve in a gas system, depending of the fluid properties and pressure drop at the restriction, during the depressurizing process the valve body may reach a very low temperature. So, material specification for the valve internals and body should be compatible for low temperature operation.
Kinds Regards,
WSN.
Kinds Regards,
WSN.
Posted 28 December 2007 - 10:52 AM
@Vinod,
To summarize what was said, a PSV is treated as a nozzle and thus is calculated as an Isentropic expansion, constant entropy. Orifice and valves (control valve being one of them) are treated as Isenthalpic expansions, constant entropy.
Posted 28 December 2007 - 11:46 AM
QUOTE (pleckner @ Dec 28 2007, 07:52 AM) <{POST_SNAPBACK}>
@Vinod,
I'm sure Phil intended for the last word to be "enthalpy".
Posted 28 December 2007 - 06:25 PM
OOOOPS!
Thanks, it is "enthalpy".
Posted 29 December 2007 - 11:05 AM
Thanks everybody for the answers...........
Isenthalpic Throttling With Flashing LiquidStarted by Guest_lofarcio_* , 06 May 2022 |
Isenthalpic Expansion Valve CalculationStarted by Guest_Bitan729_* , 13 Sep 2021 |
![]() Isentropic Efficiency Compressor And TurbineStarted by Guest_panoskagiou_* , 15 Feb 2020 |
Direct Intergration Of Isentropic Nozzle FlowStarted by Guest_Sara Owens_* , 19 Mar 2019 |
Calculation Of Thermodynamic Properties For Isentropic CompressorStarted by Guest_Matt93_* , 08 Sep 2017 |
