Confusion Over "temperature Approach"
Posted 09 January 2008 - 11:15 AM
According to some there are two approaches
Outlet temperature of hot fluid - inlet temperature of Cold fluid= (40-25) C= 15 C &
Inlet temperature of hot fluid- outlet temperature of cold fluid= (95-35) C= 60 C
Whereas some other literature states that it is the difference of the lowest temperature attained by hot stream & the highest temperature attained by the cold stream
That is : Outlet temperature of hot stream- outlet temperature of cold stream= (40-35) C= 5 C
Which one is correct ?
Posted 09 January 2008 - 01:03 PM
Without specifically stating the reference temperatures or explaining which terminal is being compared, no one is correct in this case. The matter of stating a “temperature approach” without making reference to which temperatures one is applying the “approach”, is simply sloppy and inept engineering because it can cause errors, confusion, or simply misconception of what is meant. This is the stuff out of which bad communications is made of. It is analogous to mentioning “standard conditions” without referencing specifically what are the so-called conditions. This continues to be a sore point because many engineers simply are lazy, don’t understand what they are talking about, or just plain don’t care if they are understood or not.
This type of stuff should be immediately “snuffed out” and outlawed at the academic level in order to spare engineering students a lot of future grief and problems in trying to understand just what is being explained. Unfortunately, this is not the case and sloppy teaching and text book writing continues to create and foment sloppy engineering. This is the same kind of communications skills that caused the Mars explorer project to spend countless millions of dollars only to discover that the Mars rover vehicle was programmed in the wrong units and rendered useless. Another example of laziness in communications.
Do not waste your valuable time in trying to believe that there is an “International Standard” on the definition of temperature approach – and that it is respected and practiced by 100% of all engineers. It doesn’t exist – and even if it did, many would not pay the slightest attention to it. Always work under the concept that you must demand a specific explanation or definition of what other engineers mean when they throw such verbiage at you – things such as “standard conditions”, acronyms, code assertions, etc., etc. Always demand specifics when you don’t know or don’t understand. It is not a crime nor a sin not to know what is in other people’s minds. If they want to communicate with you, it is their obligation to see to it that you receive the accurate and complete information. If you don’t receive it, then ask for it.
There are two temperature terminals in each normal heat exchanger. There can be more. There are also parallel flow and counter-current flow. But the point is that we can’t know for sure which “approach” is meant unless we are told.
Posted 14 January 2008 - 01:49 PM
Just my humble opinion (and vast amounts of personal encounters with sloppiness),
Doug
Posted 15 January 2008 - 08:39 AM
It often makes sense, to use the minimum temperature difference between the cold stream and the Hot Stream.
In theory you have to check everywhere along the heating/cooling curve.
In practice, very often the minimum temperature approach will occur at either end. But not always.
So in your exemple case an educated guess would be to use 15°. Since the hot-inlet <-> Cold outlet difference is much greater than the cold-inlet <-> hot outlet T difference it is likely that the mimimum temperature difference alond the heat curve will be 15°
Posted 16 September 2009 - 03:50 AM
Page 106 of "Fundamentals of heat exchanger design" By R. K. Shah, Duan P. Sekulić: "Temperature Apporch in counterflow heat exchanger as Absolute{(Temperature hot side inlet - Temp. cold side outside),(Temp.hot side outlet - Temp. cold side inlet)}=ABS{(95-35), (40-25)}=15"
Posted 16 September 2009 - 01:37 PM
The approach temperture for co-current flow heat exchanger is 40-35 = 5 oC
Please notice that it is not necessary that approach temperature is at the hot end/cold end of a counter flow heat exchanger. If a phase change is involved during the heat transfer process, the approach point may be in the middle heat exchanger some place. As shown on the attached typical steam generator curve, the approach point is B rather than highest temperature point A or lowest temperature point B.
Posted 17 September 2009 - 04:23 AM
The minimum temperature approach is considered to avoid temperature cross,and in any case (cocurrent/countercurrent) would be as:
Posted 17 September 2009 - 08:29 AM
The first potion of your statement is correct but the second potion and the formula are incorrect. As indicated in the attached Chart 4, although Outlet temperature of hot stream - outlet temperature of cold stream = 0 in a counter current flow heat exchanger, there is no temperature cross at all.
The approach temperature is the minimum temperature difference between hot stream and cold stream in a heat exchanger.
Posted 18 September 2009 - 09:54 AM
Contrary to your thinking,your explanation confirms my statement:
You mentioned in chart 4 approach=0 and there is no temperature cross.It is right and usually 5 C is considered as minimum approach for e.g. S&T heat exchanger.
Your second statement "The approach temperature is the minimum temperature difference between hot stream and cold stream in a heat exchanger" also confirms my above equation to define approach,because minimum temperature difference in co/counter current flow would be between outlet temperatures of cold and hot streams.
#10
Posted 21 September 2009 - 06:21 AM
Then, how will you explain attached Chart 5 and Chart 6? There is no temperature crossover even if Hot Outlet Temperature – Cold Outlet Temperature < 0 in Chart 5. There is temperature crossover although Hot Outlet Temperature – Cold Outlet >0 in Chart 6. Also, as shown on Chart 6, the miminum temperature difference is not always at outlet of cold and hot streams.
Posted 22 September 2009 - 11:51 AM
A temperature cross situation is: "where the cold stream leaves at a temperature higher than the outlet temperature of the hot stream", thus contrary to your statement about chart 5 there is temperature cross in this chart.
In the charts you have attached to your post,the horizontal axis should indicate the "exchanger length" not "duty".Based on this,the situation presented in chart 6 couldn't be acceptable,and two streams won't being interrupted.
#12
Posted 23 September 2009 - 06:36 AM
Your definition of temperature cross is for co-current flow heat exchanger. If there is no problem even if the temperature cross situation happens in the exchanger as shown on my Chart 5, why do you need to concern it?
Chart 6 is typical steam boiler curve. The horizontal axis is "Duty" or "Duty Transferred". The horizontal potion is cold stream (water) at the saturation condition (duty increase without temperature change).
Truth is still truth. It doesn't matter you accept it or not.
#13
Posted 23 September 2009 - 08:20 AM
My definition about temperature cross occasionally is applicable for countercurrent situation.
I have no concern about temperature cross. Pure (actually almost pure) countercurrent service results in temperature cross situation.
Horizontal axis should be "exchanger length".
I agree with your statement as: "Truth is still truth".
#14
Posted 23 September 2009 - 02:12 PM
The whole discussion here is about approach temperature (>0) to avoid heat exchanger temperature cross. If you don't care about temperature cross, you should not jump in the discussion in the first place.
As indicated in the attached Fig 9-2 from GPSA, temperature vs. duty chart is a common practice for a heat exchanger analysis. If horizontal axis is "exchanger length", what is the length? Shell length or Tube length? What should you do for a multi- pass heat exchanger? How should you take length for a Plate Frame heat exchanger?
Of cause, you have the freedom to make any charts you want and to define any terms you like.
Posted 24 September 2009 - 05:16 AM
The discussion is about confusion over "temperature approch" and i think every body should be allowed to jump in the discussion to submit his/her viewpoint.
When we present some charts for general discussion about "temperature Approach" or temperature variation in heat exchanger tube/shell length,as mentioned e.g. in Kern/Holman heat transfer books, usually the horizontal axis indicates exchanger length.
#16
Posted 25 September 2009 - 10:02 AM
#17
Posted 09 January 2010 - 05:59 PM
Page 106 of "Fundamentals of heat exchanger design" By R. K. Shah, Dušan P. Sekulić: "Temperature Apporch in counterflow heat exchanger as Absolute{(Temperature hot side inlet - Temp. cold side outside),(Temp.hot side outlet - Temp. cold side inlet)}=ABS{(95-35), (40-25)}=15"
WATER IS NOT CLARIFIED, UNLESS IT GETS TURBID FIRST
(Turkish proverb)
A real interesting hot thread, noted by me after some delay. I will also need some more time to "digest" it!
Anyhow, in my work we use the term "approach" according to above definition. Term "Absolute" is better expressed as "Minimum" in my opinion. A value of 5 0C - 10 0C is recommended as minimum for an "economic" exchanger, but this is not a "must". Of course process may dictate a higher value.
In case of co-current flow (where no real possibility of temperature cross) it is the temperature difference of outgoing fluids.
Edited by kkala, 10 January 2010 - 05:57 AM.
#18
Posted 16 July 2012 - 02:12 AM
#19
Posted 18 July 2012 - 12:16 AM
#20
Posted 27 February 2013 - 06:56 AM
Its a very confusing topic or I guess it has been made confusing by various view points of few professionals.
I feel Kkala has summarized the temperature approach part in his last post.
I am attaching my learning & understanding about the temperature cross, which was also a reason of confusion.
What I feel is temperature cross should be avoided because the cold fluid at one point starts behaving as a hot fluid i.e. initially the moment when the cold fluid was taking in the heat, after it enters temperature cross region it starts behaving as a hot fluid and now instead of taking in the heat it starts giving of heat because it is at a higher temperature now.
Kindly correct me if I am wrong.
Posted 27 February 2013 - 07:58 AM
Oh, how so? The hot fluid (the upper line) is always above (hotter) the cold fluid (lower line). So how does the heat flow in the other direction?
Flowing Temperature- PsvStarted by Guest_stu_* , 17 Feb 2025 |
![]() Temperature PredictionStarted by Guest_paul_ohoir_* , 10 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
