n-Hexane + wax mixture is heated with LP steam. The purpose of paddle agitator is mixing and heat transfer.
Details/Data:
Paddle quantity:2
Paddle dia:2.4 meter
Agitator rpm: 25
Vessel ID: 3.32 meter
Baffle quantity: 2
Opearting pressure: 0.2 kg/cm2g
To Estimate Hp Of Paddle Type Agitator
Started by empower70, Jan 16 2008 06:06 AM
Posted 16 January 2008 - 06:06 AM
Posted 17 January 2008 - 12:34 PM
References that speak to mixing are Perry's Handbook (any Edition), Oldshue's Fluid Mixing Technology, Lightnin's A Guide to Fluid Mixing, and Chemineer's reprint from Chemical Engineering Magazine Liquid Agitation.
For design viscosity less than 100 cP, I got 5.3 kW for a pitched blade turbine with 4 blades.
Posted 18 January 2008 - 01:02 AM
Thanx latexman,
Most conventional references, I guess, give design for single paddle agitator.
Is it ok to multiply power for 2 paddle agitators by 2?
empower70.
empower70.
Posted 18 January 2008 - 11:36 AM
QUOTE (empower70 @ Jan 18 2008, 02:02 AM) <{POST_SNAPBACK}>
That is the usual practice. It is conservative, but not overly conservative.
Posted 20 January 2008 - 11:21 PM
Thanx latexman.
In the meantime, i would appreciate, if u could share website/hyperlink for the references u have mentioned, for estimating power for the said application.
empower70
empower70
Posted 18 March 2008 - 07:05 AM
hi!
the best reference is '' horsepower tables for agitator impellers,'' l.t.advani, gulf publishing co.
isbn 0-87201-368-5
pity it's out of print. try amazon used books.
Literature cited :-
1. L.T.Advani – Horsepower Tables for Agitator Impellers –
Gulf Publishing Company.1976.
2. Holland F.A. --Chem. Engg.- 69 (19) (1962)
3. McCabe & Smith – Unit Operations of Chem.Engg.-
McGraw Hill.
4. Holland & Chapman – Liquid Mixing in Stirred Tanks –
Van Nostrand Reinhold.
5. Dudley – Gear Handbook – McGraw Hill.
6. Chemineer Inc. – Chem. Engg. Refresher – Liquid Agitation –
Chem. Engg. Magazine – 1975/76.
7. Greaves – Gearbox Ratings & Selection Catalogue.
Note : In literature cited at serial no. 1, the net hp. is in tabular format,
generated on an IBM 1401 computer, using inputs such as impeller
type, impeller dia., liquid SG, viscosity & impeller speed.
isbn 0-87201-368-5
Literature cited :-
McGraw Hill.
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
![]() Controlled Type Blowdown Through Vent Stack, Reach Mach 1Started by Guest_x127127@hotmail.com_* , 16 Dec 2017 |
