Hi all,
Quick question, I cannot seem to be able to define the units for the flowrate of my streams. Currently, when I double-click on a stream and go to Flowrate and Composition, the flowrate's units are kg-mol/hr. I would like this to change to be m3/hr as this is what my plant data is in. Is there a way I can define a stream's composition on a molar % basis and then still have the overall flowrate in m3/hr? I cannot seem to find out where to change it!
Thanks and regards,
Tom Pritchard
Pro Ii Flowrate Unit Definition
		 Started by , Jan 17 2008 04:59 AM
			Posted 17 January 2008 - 04:59 AM
			Posted 17 January 2008 - 06:34 AM
					Schismatic,
Put cursor in the flowrate block and then click on 'UOM' button in the menu bar.
You will be able to change the appropriate units as per yr requirement.
The same change can be done in individual component's column also.
Shreyas
Shreyas
			Posted 17 January 2008 - 11:09 AM
					Hi Schismatic,
Under input button in the toolbar, click on units of measure, there you can define the input units.
Hope this helps,
Laobill
Hope this helps,
Laobill
			Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025  |
		Aspen Hysys Simulation Of Acid Gas Removal UnitStarted by Guest_R.t_* , 22 May 2025  |
		 Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025  |
		 Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025  |
			Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025  |
