Dear Sirs,
I am presently working on a HP chemical dosing system (Tri sodium phosphate) for 80TPH boiler.
Please help me in calculating the metering pump flow rate and chemical dosing charge rate for the boiler.
Below are the relevant data:
Boiler steam rate: 320000kg/hr
Blow down: 3% - 9600 kg/hr
Chemical - Trisodium phosphate (Mol.wt - 380)
Residual phosphate to be maintained in steam drum - 7 ppm
Solution strength - 1%
Advance Thanks
Chemical Dosing Rate Calculation
Started by rangaraj, Feb 12 2008 06:05 AM
Posted 12 February 2008 - 06:05 AM
Posted 12 February 2008 - 08:43 AM
QUOTE (rangaraj @ Feb 12 2008, 07:05 AM) <{POST_SNAPBACK}>
Dear Sirs,
Advance Thanks
Advance Thanks
rangaraj,
Welcome...
Assuming there is NO phosphate leaving with steam by carry over,
Quantity of phosphate feeding to drum via injection = quantity of phosphate leaving drum via blowdown
1st, you can calculate the quantity of phosphate leaving drum via blowdown as you know the phosphate concentration in steam drum (e.g. 7 ppm) and blowdown rate (e.g. 9600 kg/h) ...
2nd, you have the concentration of phosphate feeding (e.g. 1%) to drum via injection...
You can calculate quantity of Trisodium phosphate feed...
Remaining is just arithmatic and unit conversion problem for you...
Posted 13 February 2008 - 10:35 AM
Just elaborating slightly on what Joe has said, I think of your blowdown water flowrate as 9600kg/hr + 99% of the chemical dosing rate. The phosphate flowrate is 1% of the chemical dosing rate. Total blowdown rate = 9600 + chemical dosing rate. So your phosphate concentration = 7 ppm (by weight) =
1% * chemical dosing rate / {9600 + 99% * chemical dosing rate)
There's only one unknown in this equation, so it is quite easy to solve for.
In fact, the chemical dosing rate is probably <<< blowdown rate, and so can be neglected in the denominator.
Doug
Doug
Posted 13 February 2008 - 11:36 PM
Thanks all for your replies.
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , Today, 07:13 AM |
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
Psv Release Rate Vs TimeStarted by Guest_stu_* , 30 Nov 2024 |
