I am a chemical engineering graduate of 1960s. Currently I am working as a free lance consultant; having worked for almost 30 years in consultancy firm in project management and project controls.
Currently I am working on a Technoeconomic Feasibility Report for production of Epichlorohydrin (ECH) from propylene and chlorine. The client is a caustic soda manufacturer and is looking for value-added product for chlorine.
From the process details available in the technology books, as also in some of the patents, I notice that though it does mention that the dicholrohydrin can be coneverted to ECH by using an alkali; but in all the examples that have been cited, I find that invariably milk of lime i.e. Ca(OH)2 is being mentioned.
My question is - can NaOH be used in this step? Reason I am seeking this information is that by using milk of lime calcium chloride gets generated that has to be disposed off; whereas if it is possible to use NaOH then NaCl will be generated that can be fed back to the Caustic Soda plant.
I also notice that ECH gets hydrolysed by 10% solution of NaOH to Glycerine. Is that the reason for not using NaOH in the ECH production step?
Thanks in advance
R N Kapur
Epichlorohydrin (ech) Manufacture
Started by R N Kapur, Mar 26 2008 07:56 AM
No replies to this topic
Posted 26 March 2008 - 07:56 AM
Chlorinated Polypropylene (Cpp) ManufactureStarted by Guest_Ajay S. Satpute_* , 16 Jun 2017 |
Consultant To Design And Manufacture Refrigerant Air DryerStarted by Guest_ravichandras_* , 25 Nov 2016 |
![]() ![]() Calculated Capacity For Psv Deviates From Manufacture's ValuesStarted by Guest_Mohammed Aljabobi_* , 01 Aug 2014 |
Manufacture Of Solid Nahso3Started by Guest_sagarnirgide1991_* , 10 Jan 2013 |
Solar Panel & Accesories ManufactureStarted by Guest_Chemical Rec_* , 25 Mar 2013 |
